Old 06-14-2005, 02:14 PM   #1
ACES
Life is a gamble
ACES's Avatar
Rivet removal
I'm trying to install a sway bar, but to do that, I have to remove two rivets. I've started on the first. Its on the driver's side. I have ground off the top of it with a grinder. I've been using a punch and hammer to push the rivet through. So far I've only moved it about a 1/16th. I've sprayed it with PB Blaster several times. Any suggestions?
I know that many of you on the board have done this mod. I figure someone can give me some advice.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 06-14-2005, 02:15 PM   #2
farside847
farside847's Avatar
I ran into the same problem. I ended up drilling them out after flattening the tops with the grinder. Beware of hot shards of metal!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 06-14-2005, 02:17 PM   #3
StingRay
StingRay's Avatar
Pretty much need an air chisel. The best way is to knock off the head with a chisel and then switch to a punch and drive it through if the air chisel isn't quite powerful enough to take the head off drill it with the biggest bit you have first and it'll make it easier. You can probably blow em through with a plasma as well.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 06-14-2005, 03:32 PM   #4
71-longbed
Its Magically Delicious
71-longbed's Avatar
put the front end on ramps and get yourself a bigger hammer ... it'll come
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 06-14-2005, 03:33 PM   #5
69 Short Fleet
I drilled mine out, make sure your drill bits are SHARP and I left my cordless drill in the case and used my elec. drill. As mentioned watch out for hot pieces of metal and protect them eyes. Doug
69 Short Fleet is offline   Reply With Quote
Old 06-14-2005, 03:41 PM   #6
cadiac
Air chisel -old rivet gun will do in a jiffy. I have an old air craft factory rivet gun that I use. They ricochet like bullets. Be carefull. "Goggles"
cadiac is offline   Reply With Quote
Old 06-14-2005, 04:43 PM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-14-2005, 05:19 PM   #8
mitchfab
Junk Chevy C20 Big Block
heat!
mitchfab is offline   Reply With Quote
Old 06-14-2005, 05:46 PM   #9
boraxman
Keepin an eye out
boraxman's Avatar
If you keep hitting it it will come out.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-15-2005, 09:38 AM   #10
Putter
More Cowbell....
Putter's Avatar
A wise man once said....
"Just keep beating on it.....it HAS to come sooner or later"
...but he was naked when he said it, so....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
