Old 06-16-2005, 10:21 PM   #1
Sierra88
Cool 87 Suburban need help
Someone told me if I take the fuel lines off at the throttle body and turn the key that gas should come out of them. Is this true, because mine isn't doing that and I need to get this thing running. 87 Suburban half ton 350 4wd.
Sierra88 is offline   Reply With Quote
Old 06-18-2005, 04:19 AM   #2
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
Yes, it's true. Could be a bad fuel pump, or wiring going to it.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
Old 06-18-2005, 09:40 PM   #3
bisquik65
bisquik65's Avatar
Welcome to the board from western n.c. If you take a hammer and (smack) your tank and it will start,fuel pump...The fuel pump relay is under the hood ,bolted to the fire wall..and there is a in line fuse near it too...Try these 3 things...it has to be simple...And could be a lost ground or broken wire near the tank too..Common Hope this helps,Erick
Bob there is a great one when it comes to burbs too...
bisquik65 is offline   Reply With Quote
Old 06-18-2005, 11:53 PM   #4
Sierra88
thanks, i will check it all
Old 06-19-2005, 06:35 PM   #5
Sierra88
Does anyone know where fuel pump fuse is? Fuel pump Relay? I can't find it. On 93 Suburban it is bolted to the firewall on the left. But in the 87 nothing is their and i can't find it.
Old 06-19-2005, 07:23 PM   #6
Sierra88
nevermind found it
88 Gmc Sierra 1 Ton 4x4 454 7.4Lt.
87 Chevy Suburban 1/2 Ton 4x4 350 5.7 Lt.
93 Chevy Suburban 1/2 Ton 4x4 350 5.7 Lt.
Old 06-19-2005, 07:28 PM   #7
bisquik65
bisquik65's Avatar
I know you can do it!!!
