Old 06-18-2005, 01:12 PM   #1
Nima
Blue 67
Another basic question:
Hello all;
I don't know if this has been discused at this level, if it has please direct me to it, if not please through some light here. For somebody like me with minimal knowledge, would you explain the relation between different gear ratio with towing, tire size, gas milage etc. What are the limitations when you decide what gear ratio is best for you use. sorry if it is too basic.
Thanks and hope everybody is having good weekend.
Nima is offline   Reply With Quote
Old 06-18-2005, 01:40 PM   #2
ckhd
ckhd's Avatar
Well, generally, the lower the gears (higer number), the more multiplication of power.
What this translates to is lower gears means you can pull heavier loads, accellerate faster, use bigger tires, that sort of thing. The downside to low gears is that it means your engine turns faster to achieve the same speeds. That means lower mileage.
Personally, I feel that 3.73 gears are the best compromise for me, at least with my four wheel drives. It gives me liveable RPMs at highway speeds, OK mileage, and OK towing and four-wheeling. That is with 31-33 inch tall tires.
If I was building a purpose-built vehicle, it probably wouldn't have 3.73s. If I was building a pickup for mileage, it would have 3.54s or 3.07s. If I was building a rock crawler, it would have as low of gears I could find. If I was building one to pull big heavy trailers, it would have 4.11s or 4.57s and a big block. It all depends on application.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 06-18-2005, 01:54 PM   #3
Nima
Blue 67
Thanks. I can undrestand that!
