Old 08-09-2002, 03:54 PM   #1
Dan67
Bench seat interchangeability
Can anyone tell me what other bench seats might fit the '67-72 pickups? My original '67 bench seat is collapsing where the driver sits (it was like that when I bought it, I swear... ). Rather than try to repair the existing one, I thought it might be feasible to find a complete seat from a later-model truck or car that would fit (with minimal drilling/cutting). I'm getting tired of sitting so low!
Thanks for your help,
Dan
1967 Chevy C10 LWB
Dan67 is offline   Reply With Quote
Old 08-09-2002, 04:05 PM   #2
ThreeQuarter
ThreeQuarter's Avatar
The 88-98 benches come pretty close. The front holes come very close to lining up exactly; you just have to loosen the bolts on the bench frame and "stretch" the frame slightly. And that puts the rear of the seat in a place where it'll need about a 1" tall spacer and a new hole in the floor for the bolts. Be sure to reinforce the floor around the new bolt hole--don't want that thing pulling through in a wreck!
Or if it's too close to the steering wheel or too tall, you can scoot it back and drop it down 1" and make 4 new holes in the cab floor for it. Since the cab floor is mostly flat, there's some leeway here on how to do it. The 73-87 floors were not flat and it's not easy to swap those benches into these cabs. Good luck!
Oh, and the 88-98 benches are a slimmer profile, giving some more leg room to tall folks.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 08-09-2002, 05:19 PM   #3
johnnyp
Keepin' It Stock
johnnyp's Avatar
Might be easier and cheaper to have the original seat repaired. I had a local shop replace broken springs, add some new foam in a few areas, and put on new seat cover (I bought the seat covers myself) and they only charged me $65. I couldn't believe the difference. Before, I always felt like I was going to fall out of the door but now it sits nice and firm. You might want to take your seat to a local shop and have them give you a quote.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 08-09-2002, 05:37 PM   #4
smitty62
smitty62's Avatar
Unhappy
The '67/'68's were a terrible seat and not worth rebuilding--still wouldn't be any good after. Try to find a '71/'72 seat to rebuild
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 08-09-2002, 05:50 PM   #5
jostrans68
Jostrans68
jostrans68's Avatar
I have to disagree on the 67-68 seats My original seat is in great shape 280,000 on truck the original foam is good and springs solid and I weigh 350 and have driven it for 14 yrs and my dad had it since new.. I am recovering it now. the original cover is still ther but it let go at seams and is faded. Mu .02 worth and it folds forward..........................
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 08-09-2002, 06:02 PM   #6
woodrow59
OzarkHillbilly in Atlanta
jostrans68 ,,,, Mine's original too (at least I think). Haven't had mine redone yet but the foam and springs are in great shape.
???? Mine folds forward too. I don't remember my dad's '70 doing that. Was this only certain years or different packages ??
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 08-09-2002, 06:22 PM   #7
smitty62
smitty62's Avatar
You must have a deluxe seat while all I've been around were standards--which are junk. They only used bed springs with a covering of burlap-then the upholstery--NO foam! '71/'72 seats had a THICK foam over the springs--I have both here. Take a look at the vendors catalogs--the thick replacement foam is not for the early seats--it would set you up too high. When I get the rest of my interior done, I will throw the '68 seat away and put my newly recovered '72 seat in. They will all tilt forward if the nuts are removed from the back support--BFD--not supposed to be that way--what's the point? No room back there unless you've removed the gas tank. just my 5 cents !
Smitty
Old 08-09-2002, 06:37 PM   #8
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
Buckets?
are you set on bench seat, or are buckets an option?
cuz man, i bolted in a couple of 94 jeep grand cherokee buckets and they fit so nicely...and believe it or not, it really improved the ride in the truck, went from really bouncy to nice and comfy and tight fitting...and they lined up to the holes from my bench (67) except i had to drill the 4 inner holes.
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 08-09-2002, 07:59 PM   #9
jostrans68
Jostrans68
jostrans68's Avatar
I have 2 68 benches and they are both foam covered the one in the original truck my dad got is stock no option on the sticker for deluxe seat. so I dont know I have had 2 68's 1 69 adn one 72gmc all had this style seat and they folded forward....... maybe its a west coast thing? shooting in the dark with that one LOL Jack
[CGTW Member
Old 08-09-2002, 09:33 PM   #10
Southpa
Southpa's Avatar
Heres my original bench (1970), I know, looks like sh$t with the cover off.
I didn't want to get sidetracked on this one as I was in the process of doing body work. So I put the cover back on after cleaning it and put it back in the truck. It sags slightly, but still comfy. Maybe I'll replace it later, but for now, it will just continue to collect fartzzzz.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-09-2002, 09:37 PM   #11
mikep
Used to have a truck
mikep's Avatar
Ive got a fully recovered and refoamed 71 seat in my 68. It sits up a good bit higher but man is it comfortable compared to the original. Night and day ! God bless my neighbor who gave the new interior set to me.
No truck :-(
mikep is offline   Reply With Quote
Old 08-13-2002, 08:46 AM   #12
Jwill41
Jwill41's Avatar
This is my 68. The seat was in it when I bought it. It feels much better than the buckets in my 67.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
