Old 06-24-2005, 02:15 AM   #1
Russell
Professional Grade
Russell's Avatar
Progress Report!
Woohoo! Got all my electrical on the interior done today! The TPI harnesses are working perfectly, and less the seatbelt light, the entire truck's harness works now as well (I am fairly sure the seatbelt light is just something loose, as I did see it work tonight). Even got my remote door lock controller / remote starter working as well I've still got a couple little courtesy modules I want to install (courtsey light delay that keeps the interior lights on for 10 seconds, then fade off unless the truck is put into gear, at which point they turn off immediately a headlight delay that keeps the headlights on for 30 seconds after the truck is shut down and a photocell which will turn the clearance lights, tail lights etc on when it gets dark out, the headlights will be on at all times)
Tommorow I will put the interior back together, maybe I can actually sit in my baby tommorow
All that is left before I can fire the TPI up is a heater hose that goes between the lower intake and the throttle body, a thermostat housing, an upper rad hose, install the electric fans, fuel lines, and to install the Suburban tank. After the engine is running, it will only be a matter of days before I can have the truck back on the road
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-24-2005, 04:48 AM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Making some damn good progress. Going to be sweet when its all done. Where are the pics at?
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-24-2005, 09:31 AM   #3
k72516
k72516's Avatar
Yea, let's see some pix. It sounds like you did a good job, show off time!
Go Fast - Be Loud
k72516 is offline   Reply With Quote
Old 06-24-2005, 10:59 AM   #4
Russell
Professional Grade
Russell's Avatar
Pics are coming tonight My sister has had my camera for the past couple of days
Old 06-24-2005, 09:21 PM   #5
Lynx
Lynx's Avatar
Im definatly going to have to visit you this fall when you got that baby done!
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
