06-24-2005, 04:02 PM | #1 |
Help!!!!!!!!!!!!
I need some help with spark plugs. I went to parts store and got the "correct" plugs for my 1969 Suburban, R43. I come home and pull out the first plug and guess what it's different than the ones I got, R45T. Which one is correct?
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-24-2005, 04:19 PM | #2 |
MY EX DRIVES A BROOM
it all depends......do you have points or hei
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
06-24-2005, 04:41 PM | #3 |
computer illiterate
the r43 is for use with a points distributor and I use the r45ts's with hei
72 2wd blazer 72 swb 4x4 |
06-24-2005, 04:42 PM | #4 |
my gas saver
not much diff in the plugs. i've got 45's in my 350 and 454, and the 43's in my 4.3 v6. they may work at a diff temp or have different lengths or????? but they're all pretty much similar. just gap em around .45 if you have hei and you should be fine.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
06-24-2005, 05:07 PM | #5 |
It's got points.
06-24-2005, 05:08 PM | #6 |
computer illiterate
with points they should be gapped at .035
06-24-2005, 05:17 PM | #7 |
I tried to thread the R43, it won't even start. I guess I'll put the 45's back any unless any one has a better sol'n.
Rob
06-24-2005, 07:25 PM | #8 |
Does anyone know the difference between R45T and R45TSX?
Rob
06-24-2005, 08:13 PM | #9 |
Here is a link that is pretty helpful and you may want to book mark it.
The R43 does not have a tapered seat but R43T does. S= extended tip, x=wider gap. I like to use the R45TSX based on the way I drive, (mostly short trips). The number breaks down like this: R=resistor 45=heat range, (larger no is hotter plug) T=tapered seat S=exteded tip X=wider gap Using the plug with the X is a good practice with HEI as the spark plugs are gapped wider and the bendable tip can be kept parellel to the other tip. Plugs without the X will work, however. Jim http://www.acdelco.com/html/pi_plugs_ident.htm |
06-24-2005, 09:42 PM | #10 |
Thanks Jim,
If I use the R45TXS with the points, should I still gap it at .035? Rob
06-24-2005, 10:14 PM | #11 |
Designated A-hole!
Yes, gap for hei is .045
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-24-2005, 10:15 PM | #12 |
I have points and condenser, should I gap to .035 or .045.
R
06-24-2005, 10:46 PM | #13 |
My research says with points... gap at .035, unless you are using an aftermarket high output coil, then my best advice is to gap at .040.
06-24-2005, 11:02 PM | #14 |
Thanks everyone.
Rob
