Old 06-25-2005, 10:27 PM   #1
Purs
Got Big Block?
Purs's Avatar
Motor Mounts
Does anyone sell solid motor mounts for our trucks? I think I need them I fired up the 496 today and that thing was rockin' (literally!) Anyway, my header clearance is pretty close in some places so I'm trying to keep the twist down to a minimum. Any help would be appreciated.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 06-25-2005, 10:46 PM   #2
Purs
Got Big Block?
Purs's Avatar
found these:
http://www.performancesuspension.com...ransMounts.htm
Anybody used them or something similar?
Old 06-25-2005, 11:23 PM   #3
ed455
Captain Ed
If it's a street vehicle, you'll hate solid motor mounts and it will literally cause bolts to come loose in all sorts of places. Been there, done that.
The alternative is a torque strap. Some woven steel rope terminated in loops at the end to attach to the driver's side of the engine and the frame. An even easier alternative is a piece of chain doing the same job of limiting engine lift. I've done both and they work well limiting engine movement while maintaining the vibration dampening that rubber motor mounts are designed for.
On my Olds big blocks I would drill completely through the rubber mounts and through-bolt with a grade 8 bolt in a 5/16" size with a lock nut. I wouldn't tighten it down all the way so there was some damping ability of the rubber mount.
Just some ideas, but unless it's an all out drag motor, solid motor mounts are bad news. Even then, it's a better plan to go with engine plates.
ed455 is offline   Reply With Quote
Old 06-26-2005, 09:29 AM   #4
55454
55454
55454's Avatar
I have the factory cables and brackets for a small block.
55454 is offline   Reply With Quote
Old 06-26-2005, 11:51 AM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Heres an option
http://performanceonline.com/store/c...396&cat=&page=
kelsfine69 is offline   Reply With Quote
Old 06-26-2005, 08:03 PM   #6
Purs
Got Big Block?
Purs's Avatar
anybody used these?
Old 06-26-2005, 10:41 PM   #7
kelsfine69
18 Till I Die
kelsfine69's Avatar
They do sell them without the poly mounts, so you can run some Moroso solids. Theres a tech artical in Classic Trucks Mag this month, about these. I was thinking about buying a set and going with the Energy poly mount ( because they have red). Right now I have big block Towers with small block pads, and I dont have any twisting problems. I just thought I would clean it up a little
Old 06-26-2005, 11:26 PM   #8
cdowns
cdowns's Avatar
it should be easy to make solid mounts out of steel plates,if you really want them
the torque straps are a good idea i've used them made with turnbuckles so they were easily adjustable
