Old 06-27-2005, 02:29 PM   #1
88JIMMYFAN
88 Jimmy Help Needed
I have a 88 Full size Jimmy with the 5.7l fuel injection. My problem is that when I push on the gas pedal it sounds like clunking noise and I lose all power and it hestitates then it seems like it catches and then it takes off. But it will also do this at cruise speed. I have changed anything yet cause I'm not sure where to start. It does have 98,000 miles on it when I bought it.You can also hear one of the lifters knocking,which I can fix but want to wait until I get the other problem figured out and fixed..If you can help me I would appreciate it..Thanks in advanced
88JIMMYFAN is offline   Reply With Quote
Old 06-28-2005, 11:12 PM   #2
a28doc
'87 V20 4x4
a28doc's Avatar
sounds like fuel problem when you step on the gas it gets starved for fuel and stumbles. if you havent changed fuel filter lately that would be first place to start and very inexpensive after that use some injector cleaner to clean the injectors to make sure they are spraying correctly. if none of this works check out the fuel pump to make sure it is working properly hope this helps Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 06-29-2005, 05:11 AM   #3
88JIMMYFAN
thanks doc..I'll give it a try..can ask one question how easy is it to get to the fuel filter..I know it's in the gas tank..so do i have to take it apart?
Old 06-29-2005, 10:05 PM   #4
a28doc
'87 V20 4x4
a28doc's Avatar
fuel filter is halfway up the framerail between the tank and the engine just follow the fuel lines toward the engine until you find what looks like a metal can bout the size of a 2 cycle oil can or there bouts. the filter thats in the tank attached to the pump usu doesnt need changed until you change the fuel pump. hope this helps Doc
'87 v20 4X4
'99 S10 Blazer 4X4
Old 06-30-2005, 04:25 AM   #5
88JIMMYFAN
thanks doc..appreciate it
