Old 06-28-2005, 04:38 AM   #1
69 Short Fleet
Clutch Z-bar question
Are there 2 different clutch "Z-bars" (that pivot between the block & frame)that were made for our trucks? The PO switched out the I6 to a 283 and I think reused the original Z-bar. The engine in its furthest rear position (closest to the firewall). With the Z-bar I have it aligns the brake pushbar (one that goes through the firewall) off-centered and the pushbar rubs on the top of the hole in the firewall. And does anyone have a pic of the two side-by-side to help clear this up for me. I'd like to get the proper one. Thanks Doug
69 Short Fleet is offline   Reply With Quote
Old 06-28-2005, 06:45 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Yes the L6 Z-Bar is different from the V8 Z-Bar. One is longer that the other. Can't remember which, L6 -- I think.
Old 06-28-2005, 08:23 AM   #3
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
The Rest Of The Story
First, I want to make sure I don't step on any toes here. Sunshine has given me suggestions in the past and he is a VERY knowledgable guy. I will add what I know to his remarks. Through sheer persistance, I have gained quite a bit of info on this subject recently. The 6-cyl z-bar is 5 3/4 wide, takes a u-shaped bracket on the engine that has bolt holes 3 1/2 inches apart. The frame bracket sits to the inside of the frame rail, and the rod from the pedal is straight. SB & BB z-bar is 6 3/4 wide, SB takes a flat bracket on the engine that bolts to 2 holes that are 5 1/8 apart that are normally reserved for the pivot ball in car applications. The bracket moves the ball forward 1 1/4 inches to line up with the frame bracket. BB takes a curved bracket that goes around the oil sender hole and bolts to the aft pivot ball hole and to a smaller hole forward of the sender and below the front pivot ball hole (for cars). They both have the frame bracket to the outside of the rail, and they both take a rod from the pedal that is s-curved at the end where it meets up with the z-bar. The angles of the arms on the z-bars all look relatively the same. I hope this gives you some idea of what you have and what you need. PM if you have other questions. Take care, Mike
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Old 06-29-2005, 05:09 AM   #4
'68OrangeSunshine
Don't worry about me, Buddy, I've always got my steel-toed wingwalker boots on when I work on the engine.
I did crawl around under the '71 Jimmy K/5 to measure my only example of a V8 Z-Bar. I got about 7". But this is a 4x4 application, and there is no bracket on the engine block side. A special ballstud screws into the side of the block directly.
Also measured the old Z-Bar that was on my truck for lo--these 30-odd years --and it was 5-13/16ths" wide.
So I guess I was 180* out in my guess which was the bigger Z-Bar, V8 or L6.[At 3 AM my dyslexia filter gave out.] Good catch, Todd.
Doug have we thoroughly confused you yet?
Old 06-29-2005, 09:20 AM   #5
dubie
dubie's Avatar
I have my 350 in the inline 5 position and was able to use my inline 6 Z bar. I made up a plate welded the pivot ball to it then bolted the other end into a hole near the bellhousing using lock washers. Works like a hot damn. I got the idea from GMC Paul, he did this on one of his trucks that has over 500,000 miles on the same plat set up.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-29-2005, 03:47 PM   #6
longhorn71
longhorn71's Avatar
I have the V-8 z bar here if you need one.
longhorn71 is offline   Reply With Quote
Old 06-29-2005, 06:52 PM   #7
69 Short Fleet
thanks for all the help guys. longhorn71 dean, i'd be interested in buying it how much do you want for it? i will try to check the width of the round part + the distance between the arms on it today but it will take some time jumping into the engine bay as i sliced open my finger yesterday, 6 stiches, sorry my typing is bad, lol. i don't have any brackets on the engine side of mine, it goes directly on the block stud ball on the engine side and on the frame side has a nut that goes on the bolt part of the z-bar and it goes on a small factory bracket , rivets hold it on the frame rail. iwill be installing a new clutch soon so i'd like to have the linkage correct, + the fact i can't get the firewall clutch rod rubber boot on the way it is now. doug
Old 06-29-2005, 07:54 PM   #8
longhorn71
longhorn71's Avatar
Pm sent
Old 06-29-2005, 08:24 PM   #9
68 Stepside
huh?
68 Stepside's Avatar
Wow Tim, an inline 5?!?! I'd like to see pics of that!!!
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-30-2005, 02:13 AM   #10
69 Short Fleet
dean, pm sent, thanks, doug
Old 06-30-2005, 09:10 PM   #11
hotrodmtodd
'Burban Legend
You 4 Wheel Guys
Yeah, you 4X4 guys have it easy, you get to use the pivot ball hole like normal humans. Us 2WD guys have to use a stupid bracket! If you notice, I don't even mention anything about 4X4 in my sermon because I don't even know what color the SKY is in 4X4 World! But I am learning from Bisquik65! (thanks Erick) Take care guys, Mike
'69 C-30 dump
'71 4x4 454
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
