Old 06-30-2005, 03:23 PM   #1
PMS
Question Ceramic pads / shim?
I got a set of ceramic disc brake pads and they came with a adhesive backed shim. They did not include instructions for shim... Does anyone know which pad the shim should go on - the piston or the caliper frame?
Thanks,
Parrish
PMS is offline   Reply With Quote
Old 06-30-2005, 04:19 PM   #2
Putter
More Cowbell....
Putter's Avatar
Don't those have small dents in there to clear the pad's rivets? I stuck mine directly to the pad on my wife's Olds. I assume they are similar to those.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-30-2005, 04:59 PM   #3
sdkid
The ones I've seen are a set of 4, are one for each pad.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 06-30-2005, 06:15 PM   #4
speedracer
Blank
speedracer's Avatar
if you only had two though I would put them on the outside of the caliper and put anti squek stuff on the inside
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 06-30-2005, 06:19 PM   #5
Scrubby
Check out GMTrucks.org
I think it goes piston side. I believe that stock GM shims are only on the piston side.
Scrubby is offline   Reply With Quote
