Old 07-01-2005, 05:57 PM   #1
farside847
farside847's Avatar
Brake Booster Help
I just got a brake booster off a board member and Ive got a pretty good handle on how to install it. But I had one question: where does the vacume hook up? I have a stock 307 that originally had manual brakes.
thanks!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-01-2005, 06:02 PM   #2
smbrouss70
smbrouss70's Avatar
It should hook up to FULL Manifold vacuum, either a port on the manifold itself or to a port on the base of the carb.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-01-2005, 06:05 PM   #3
farside847
farside847's Avatar
There is a plug in the top of the manifold behind the carb - would this be a full vacuum?
Old 07-01-2005, 06:11 PM   #4
smbrouss70
smbrouss70's Avatar
Yes, just take the plug out and get a fitting to put in there to allow you hook the vacuum hose up to. Make sure you use some form of thread sealer whether thread tape or the liquid type.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
