Old 07-06-2005, 09:15 PM   #1
Hart_Rod
Hart_Rod's Avatar
Rebuilding trailing arms question
I've got a set I'm going to blast, repaint and put in new bushings. Anything else I should do sense I have them out? Weld seams? I've seen the plates that you can weld on, what is the purpose? Is it worth it? Thanks for info.
Rob
Hart_Rod is offline   Reply With Quote
Old 07-07-2005, 08:59 AM   #2
Hart_Rod
Hart_Rod's Avatar
anyone???
Old 07-07-2005, 09:04 AM   #3
Joe67
67 is sold
I saw a discussion on those add on plates a while back. It was stated they don't really do much for a driver, but more if you pull/haul heavy loads on a regular basis.
I just burned the old bushings out of my trailing arms this past weekend
What bushings will you run? I bought the poly bushing kit from PST
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-07-2005, 09:11 AM   #4
arkracing
Weekend Warrior
Mine were starting to "split" down the seams...so i clamped them back together and welded every 2-3" a 2-3" bead on both the top and bottom.
no need to weld them solid.
might not hurt to put some seam sealer in the seam if they are in good shape or after you weld them to keep water and dirt out for future rust/split prevention.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 07-07-2005, 10:10 AM   #5
Hart_Rod
Hart_Rod's Avatar
I got some from EST. Never thought about the seam sealer, that is a very good idea . Thanks guys.
Rob
Old 07-07-2005, 10:11 AM   #6
boraxman
Keepin an eye out
boraxman's Avatar
How do you know when the bushings are bad?
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 07-07-2005, 03:33 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
All that I have seen have gotten gravel and dirt between the pieces. I cleaned them out, put bolts in to hold the pieces together, and painted. You could weld instead of bolting. The plates are usually used for reinforcing a rusted out area.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-07-2005, 08:25 PM   #8
SCOTI
SCOTI's Avatar
I did the same as arkracing w/a 1.5" bead about every 6" the length of the arm, top & bottom, on both my trailing arm trucks. I also boxed the front & very rear of the arm as well on my RestoRod.
Both use urethane bushings.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-07-2005, 11:04 PM   #9
Hart_Rod
Hart_Rod's Avatar
Scoti,
Do you have any pictures? Thanks,
Rob
Old 07-08-2005, 12:53 AM   #10
SCOTI
SCOTI's Avatar
Originally Posted by Hart_Rob
Scoti,
Rob
Sorry . . .... no pics. I might be able to get some over the weekend.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-08-2005, 03:42 AM   #11
68LSS1
68LSS1's Avatar
I think this is the way to go also. Completely welding the seam removes some flexibility from the trailing arm which I've been told by Steve (owner of Hot Rods To Hell) among others, is not always a good thing. I will be adding 1/8" plates where the axle housing sits though.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
