Old 07-06-2005, 11:16 PM   #1
R@nger
Psalm 23
R@nger's Avatar
Turning signal issues
I have a slight problem..more of an inconvienance really. My turning signals are SUPER sensitive..if they are not in exactly the right spot they will blink. Also when I turn them off to take a turn after completing the turn I have to manually turn them off. There is no canceling switch. What kind of parts would I need to fix this problem and what kind of money can I expect to shell out for the parts?
By the way I've been having a blast driving my truck around!...I love this thing I'm hooked.
Thanks alot for any comments, ideas or suggestions.
Kevin
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD.
"Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy
R@nger is offline   Reply With Quote
Old 07-06-2005, 11:22 PM   #2
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Sounds like the return springs are broken. Pull your steering wheel off and look for two springs about the the diameter of a pencil. They should have one end that is angled 90 deg from the circle, if not then it is broken. Some one should have a picture here of what they look like. Chev sells them and I think they are pretty cheap.
oldiron is offline   Reply With Quote
Old 07-06-2005, 11:29 PM   #3
R@nger
Psalm 23
R@nger's Avatar
That would be great if thats all it is..I'll go look for those right now.
Thank you.
Old 07-06-2005, 11:46 PM   #4
pjmoreland
pjmoreland's Avatar
You can buy a pair of cancelling springs in the Help! section of just about any auto parts store.
pjmoreland is offline   Reply With Quote
Old 07-07-2005, 12:03 AM   #5
R@nger
Psalm 23
R@nger's Avatar
Yeah I'm not seeing any...i don't know where exactly to look but I see no springs.
I was looking online at that part and I have a question. Whats the difference between a canceling spring and a TURN SIGNAL CANCEL CAM?
oh yeah and as you can see from the last pic my emergengy flasher deal is broken
Old 07-07-2005, 12:14 AM   #6
Mongo
YES_____NO
Mongo's Avatar
The differance is between the canceling spring and a Turn signal cancel cam. is that the spring is just the sping and the cam is the whole white thing that you see in you pics.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 07-07-2005, 12:19 AM   #7
R@nger
Psalm 23
R@nger's Avatar
ahhh ok. ty.
So to just replace the springs am I gonna have to get a steering wheel puller to get to where I can put those springs in?
Old 07-07-2005, 12:56 PM   #8
Bob Moore
Yes
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-07-2005, 07:23 PM   #9
R@nger
Psalm 23
R@nger's Avatar
And done...I got all my parts and steering wheel puller today and put those springs in place. Now it works like a charm...ty guys for the help.
