Old 07-11-2005, 01:33 AM   #1
OlyHeeebz
Replacing body mounts
Anybody have any good suggestions or tips for replacing body mounts on a Blazer? Mine are all shot and I'm getting some Energy polys to replace them.
Any one have any good tips for doing this. I was just going to jack up one side of body at a time using 2x4"s and replace all the bushings one side at a time.
Can I slide in a washer or two on the bolt for a slight body lift as well?
1969 K5 Blazer CST
Always waiting for the Puget Sound sun.....
OlyHeeebz is offline   Reply With Quote
Old 07-11-2005, 07:29 AM   #2
vtblazer
vtblazer's Avatar
Some say that poly mounts squeak, so when I did mine I smeared everything with anti-seize.
Never heard a squeak yet.
vtblazer is offline   Reply With Quote
Old 07-11-2005, 10:33 AM   #3
Yukon Jack
Yukon Jack's Avatar
When I did mine I had to grind the heads off of the bolts other than the two that are located in front of the driver and passenger seats and the radiator support bolts. Then I punched the bolts down through the floor and fought to get them out below the body. The bolts were so rusty I couldn't get any of them to break free. One of the metal sleeves on one of the bolts in front of the seats was seized. Fought it for a long time and then got my handy air hammer with a v-shaped chisel head and had it off in a number of seconds.
Watch your door gaps when you tighten everything down, should use the same number of shims when reinstalled - at least I did.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-11-2005, 04:22 PM   #4
michigank5
Just like Yukon, I had to grind the heads off and then punch them through. Most or all of the heads are probably at least tacked to the body. If you have a hard top, keep it bolted on the whole time, should keep the body together better. I had sold my top already when I did the mounts and it took a lot of adjusting shims to get it back so that the doors could shut. And good suggestion by VT using the grease since mine squeak a bit, but that's easily overcome by cranking up the stereo. But you've got the basic idea, jack it up with 2x4s and go one side at a time.
michigank5 is offline   Reply With Quote
Old 07-11-2005, 11:03 PM   #5
Jimmy72custom
Jimmy72custom's Avatar
The torque is 20 ft. lbs except for the larger bolt below the windshield it is 50 ft. lbs. I put in stock rubber and double nutted the bolts after torque, no grease no squeak. But I play my CD to loud to tell anyway.
Jimmy72custom is offline   Reply With Quote
Old 07-11-2005, 11:10 PM   #6
71jimmy
71jimmy's Avatar
I just did mine, same as everyone says. I didn't "torque" mine though, just tightened until the rubber slightly bulbls out. At 20 or 50 ft lb the rubber must be flat. Might not be a problem with poly mounts though.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 07-12-2005, 11:14 AM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'm probably going to have to do body mounts this fall. After removing the top for the first time, the doors are sticking a little.
Should you put locktite on the bolts to keep the nuts on?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-12-2005, 04:19 PM   #8
OlyHeeebz
Does anyone have any preferences towards which mfg. of mounts? Energy and Prothane are the two poly mfgs that seem to dominate the market? Is one better than the other?
1969 K5 Blazer CST
Old 07-12-2005, 11:51 PM   #9
71jimmy
71jimmy's Avatar
OK, stupid thought. The metal sleeve inside the bottom mount, that is what you tighten and torque against. But the bottom rubber mount sure flattens/bulges out? Is it suppossed to? The old mounts were shot and bolts were rusted/dirty so it was hard to tell.
Old 07-13-2005, 10:03 AM   #10
wingman
While were on the topic has any one done a body lift, im considering the ord aluminum 1" since it is going to be all apart anyways.
wingman is offline   Reply With Quote
Old 07-13-2005, 12:17 PM   #11
OlyHeeebz
I was asking sorta the same question in my original post. I want about a half inch body lift only, and thought I could get do it with a couple burly washers. No one has responded yet tho........ come on people... Help a brutha' out
1969 K5 Blazer CST
