Brake problems
This is for my wifes car, but I figure hydrolic brakes are hydrolic brakes, right..
![]() The pedal goes soft(to the floor sometimes!) after the car has been driven awhile. I've bleed the brakes (4 disc) and they work fine for awhile after start-up but then go soft. What's up?? I'm thinking a weak brake line, but how do I find out?? btw, the brakes always have pressure, I'll pull up to a stop and the pedal will start losing pressure and the car will roll if I'm not careful. ![]()
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
No No
Well a leak some where would be a sign. What kind of car is it? Yes it makes a difference. an example would be; If it's an ABS eqquipt GM with no signs of fluid leakage then the ABS unit has a stuck valve.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
do you loose fluid in your resvior but not see any leaks? if so prolly the master cyl
It's a 93 Accord. The ABS light has always come on but I was always told that it doesn't affect the line pressure, so I never got it fix. And this just started a few weeks ago, and the ABS light has been coming on for years.
I did have the master cyl. replaced a year ago. Maybe something there?? The pedal doesn't go straight to the floor like there is air in the caliper. It just kind of eases on down. lol..
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 Last edited by C&C Chevy; 07-11-2005 at 03:32 PM. |
LED King
Probably a bad master cylinder.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
Robert Olson Transport
![]() Join Date: Oct 2002
prolly a bad master cylinder.. the abs unit is different that wont make the fluid leak ... and if you put a rebuilt in there its only as good as the rebuilder and kit put in there... sometimes a new one aftermarket is almost as cheap as a rebuilt one so check that out
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
I also have a '93 Accord and I had the same problem at around 110,000 miles. The master cylinder was bad. Hope this helps.
Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week. |
Does a bad master cylinder account for the brakes not working only half the time. I was thinking maybe a brake line was getting hot, as the car warmed up, and it started to fail. ???
Thanks 86. I guess that's the problem. The car has 170,000 on it, so I'm not to worried about putting alot of $$$ into it. Probably see if they can put another used cylinder on.
C&C Chevy mine has rear drum not disc. I'm not sure why it would only do it when hot though. Mine just started one day and did it hot or cold. I would still bet It's the master cylinder though.
Jeremy
Hey here's an original suggestion.... Master Cylinder...
OK, so it wasn't original. ![]() ![]() ![]() ![]() Last edited by Zilverado; 07-12-2005 at 05:54 PM. |
