Old 07-16-2005, 03:43 PM   #1
squint
squint's Avatar
Question Dual Batteries?
My 80 C10 has 2 battery holders under the hood.. Currently I am only using the main ( passenger side ) one.. I have no battery in the 2nd one..
How do i properly hook up another battery in the driverside, and what advantages is it going to provide me?..
thanks.
squint is offline   Reply With Quote
Old 07-16-2005, 04:47 PM   #2
C&C Chevy
C&C Chevy's Avatar
If you have a kickazz stereo system, it could help.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 07-16-2005, 07:40 PM   #3
Prerunner1982
Prerunner1982's Avatar
you could instal a switch to run either battery... helps when one dies and you need to start your truck.. or if you have a large stereo, winch, off road lights...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-17-2005, 05:20 PM   #4
phantom dually
Project92 SWB stepside
phantom dually's Avatar
It would be best to use a solenoid (old ford type) and wire it up to where only 1 battery is used to start the truck and the other only charges when the truck is running. This is a very easy mode to do. If you do not need additional amperage for amps. plows. etc etc then its a waste of your $$ and time.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 07-17-2005, 05:26 PM   #5
WakBordr7387
WakBordr7387's Avatar
Im running 2 batteries on my 86 c10 right now, just get an extra set of cables and connect the positive to positive and negative to negative then run the cables like normal.
86' C-10 Silverado
85' C4 Corvette
When in doubt, BURN OUT!!
WakBordr7387 is offline   Reply With Quote
Old 07-18-2005, 12:34 AM   #6
squint
squint's Avatar
Thanks for the info.
Old 07-18-2005, 07:58 AM   #7
chevyfan420
I hooked mine up positive to positive, and negative to ground instead of running 2 cable over to the main battery
80 Chevy K10 350/350turbo
86 Chevy 1/2 ton shorty project truck
79 Chevy 1/2ton 350/350turbo
not much to look at... ***Retired***
97 Chevy C1500 4.3/5 speed.....daily driver
chevyfan420 is offline   Reply With Quote
