Old 07-17-2005, 09:49 PM   #1
1Ton
1Ton's Avatar
Tranny Question
I have a 1978 Chevy 3/4ton 4x4 with a Turbo 350 trans. The park pin is broke what type of job is it to fix and what is involved?
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 07-20-2005, 09:17 PM   #2
1Ton
1Ton's Avatar
I take it noone has experienced this?
if some is good
more is better
Old 07-20-2005, 11:26 PM   #3
86k10
You mean the park pawl is broke? I've never seen one break but occasionally they do get worn off which in turn wears the ring gear teeth so they will not stay in park on an incline. I guess I've never tried to put one in while in the vehicle. The pin that holds it in can be accessed at the back of the case, there is a small cup plug holding it in and it is usually staked so you have to drill it a little bit first to knock those down, and then hopefully get the right size bit that will bite into the plug and pull it out. They are not to bad to do when on the bench but as I say I have never tried to do one in the vehicle.
98 Neon
97 Grand Prix GT
02 Grand Prix 40th Anniv.
86 GMC 5.0
77 Olds 98 6.6
REAL AMERICANS, DRIVE AMERICAN
86k10 is offline   Reply With Quote
Old 07-23-2005, 01:32 PM   #4
1Ton
1Ton's Avatar
I found the problem, the previous owner put lock out hubs on it without the parttime kit in the Transfercase. So when you unlock the hubs it rolls freely
if some is good
more is better
