Old 07-16-2005, 11:32 AM   #1
System User
Replace camshaft gear
The camshaft gear on my '64 truck straight 6 has stripped and requires replacement. The manual says that the camshaft must be removed and the gear removed and re-installed with a press - which requires removing the engine.
Is there an alternative? Grinding the gear off?
Any suggestions based on experience would be appreciated!
System User is offline   Reply With Quote
Old 07-18-2005, 12:55 PM   #2
60-66 Nut
Professional Beer Tester
Even if you do get the gear off without a press by grinding or whatever, the camshaft still has to be supported in the press to press the gear back on. But I don't think you have to remove the engine, you should be able to remove the radiator and the grill and the camshaft should come out. I find that it's much easier to go ahead and pull the engine out and hang it on the stand to work on it, rather than doing everything in the truck, but that's just me. The old six's are very easy to pull out if you are set up to do it, but if not then I guess that only leaves the alternative. Don't forget the two bolts behind the gear in the retainer plate, use the holes in the gear to get to them. Best of luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
