Old 07-21-2005, 06:49 AM   #1
norville
Turn signal help.
Hey folks, I'm at work so I hoping to figure this out before I go home.
Coming to work today the turn signal on dash just showed "on" no blinky blinky when I used the signal. No problem I think. I just figured I blew a bulb. Well, I check the other direction nothing there. HMMM. I pulled into the lot and I have both front lights when I use the turn signal I cannot see the rears. I put on the lights all seems good. But still no turn signals. The rear lights are on but no blinking.
I can't see if my brake lights are working (I couldn't find anything to wedge the brakes on.)
So, I have good lights up front and no lights in rear when I use the turn signal. But Have lights all around when I turn on the lights. Status of lights when I brake is unknown.
Any thoughts??? Is it the the can on the fuse block. Something else?? Brake light fuse is good.
bob
1986 C10 Scottsdale
5.3, TH400
norville is offline   Reply With Quote
Old 07-21-2005, 07:18 AM   #2
hobbz
hobbz's Avatar
sounds like you had a common ground for the to back lights came loose...
Hobbz-Garage
1987 Short Step 350/350
hobbz is offline   Reply With Quote
Old 07-21-2005, 07:54 AM   #3
norville
were should I start looking?
1986 C10 Scottsdale
5.3, TH400
