Old 07-21-2005, 10:02 AM   #1
Bowtie4by
Need help-key switch
I just bought a 76 4x4 for $275. The reason it was so cheap was because the guy had lost the key . My question is, can I remove the key switch without having it in the run position? Any other ideas?
Bowtie4by is offline   Reply With Quote
Old 07-21-2005, 10:07 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Locksmith? Have him/her pick the lock so you can get it into the run position.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-21-2005, 11:30 AM   #3
beaterC10
No problem. You need to pull the steering wheel and pull the turn signal switch loose to get to a slot in the column bowl. You can release the lock cylinder by inserting shim stock in the slot.
A shop manual or decent aftermarket repair manual will have detailed pictures and instructions. You don't need the key for any of this.
beaterC10 is offline   Reply With Quote
