Old 07-21-2005, 07:32 PM   #1
TEAM THC
CUSTOM CHEVY FIEND
TEAM THC's Avatar
20" WHEEL FITTMENT
Id Like To Put 20"s On My '82 C10 1/2ton 2wd 5lug
Id Like Some Info On Backing Spacing, What Are The Measurements
For My 5lug Pattern. Are Threr Any Problems With Fit(rubbing).
And Any Other Info I Need On Sizing 20s For My Truck.
TEAM THC is offline   Reply With Quote
Old 07-21-2005, 08:36 PM   #2
CHEVYE
my gas saver
CHEVYE's Avatar
these are 5" backspace, of course there's no bed on it and i haven't slammed it yet. these trucks have huge wheel wells. you shouldn't run into too much problem at all. your measurements on lug pattern are 5 on 5"
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 07-21-2005, 08:38 PM   #3
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
hey chevye, did you have any problems getting your front centercaps to work? i remeber having that truck with that wheels and had to take the dust cover off the front to get the centercap to work.
milehightoyz is offline   Reply With Quote
Old 07-21-2005, 08:41 PM   #4
CHEVYE
my gas saver
CHEVYE's Avatar
they fit right up. i have the smaller non heavy duty brakes on this truck though. i'll have to try em on my other truck since it has the heavy duties. i wonder if there's a difference in the rotor cap size of the bigger brakes, does anyone know?
71`SWB, project
ebay feedback
Old 07-21-2005, 08:51 PM   #5
milehightoyz
cool...looks like a nice project...im thinking of picking up another set for my burb. they are pretty niec wheels for the money. thanks.
Old 07-21-2005, 10:10 PM   #6
82c10
needin' money
if you don't mind, how much $$$$$
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 07-21-2005, 10:18 PM   #7
bigarmzz
bigarmzz's Avatar
those look like the "boss"...somethings 301's or 304's maybe....that are on www.bigjimsrims.com for around $145 apiece
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 07-21-2005, 10:44 PM   #8
CHEVYE
my gas saver
CHEVYE's Avatar
yeah, you can get a good used set with good tires for about $800. i'm thinking of getting 22's and 18's so i can run a 20/18 combo on the DD and a 22/20 combo when i get this other truck done.
71`SWB, project
ebay feedback
Old 07-22-2005, 01:04 AM   #9
laynlow77
the center caps on the rotors are too big to fit over some of the center caps. on my 77 i had to get the center caps machined, and the rotors machined a lil bit.
laynlow77 is offline   Reply With Quote
Old 07-22-2005, 01:29 AM   #10
bagged_and_bodydrop
Just drag it
I Have 20s Boss 305s, I think. Didnt have any problems with the center cap.
bagged_and_bodydrop is offline   Reply With Quote
Old 07-22-2005, 12:05 PM   #11
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
How wide of a wheel are you planning on going with on the front and the rear? And, how much of a drop do you have or plan to have?
5" bs on a 20x8 should work in the front. Out back, 5" bs on a 20x10 should work. If you go 20x8's with a 5" bs on all four corners, the rears will be offset in more than what is needed, but it should work. And as Chevye said, your bolt pattern is 5 on 5. If you haven't radically altered your suspension or brakes, you shouldn't have any rubbing issues with the correct offset.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 07-23-2005, 12:16 AM   #12
bagged74
its just $$$$$
bagged74's Avatar
these are 20x8s with 4.5"BS and 245/40s, and 20x9.5s with 5.5"BS and 275/35s. the fit great.
bagged74 is offline   Reply With Quote
