Old 07-24-2005, 04:42 PM   #1
dropthehammer
Needs Adult Supervision
Tail Light Fuse????????????
Hi,
I have a 71 Chevy LWB, that blows the tail light fuse every time I step on the brake pedal. The tail lights work fine, until the brake pedal is applied, then the fuse blows. Any idea or suggestions on where I should start? Thanks.
dropthehammer is offline   Reply With Quote
Old 07-24-2005, 06:01 PM   #2
byrd
Union Electrician
byrd's Avatar
Does it do that when you use the turn signals too? If not try replacing the switch on the brake pedal that makes the brake lights come on. My .02 Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-24-2005, 06:08 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
brake light switch needs replacing
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-24-2005, 08:46 PM   #4
dropthehammer
Thanks alot you guys, I will try and find a switch. Any chance a local parts store may have one?????????????
Old 07-24-2005, 09:50 PM   #5
byrd
Union Electrician
byrd's Avatar
I'm sure that a board member vendor would have it, I suggest you check them out first. Randy
Zip:40272
Old 07-24-2005, 09:56 PM   #6
cdowns
cdowns's Avatar
b-4 buying a switch get under the truck and inspect the wiring running down the drivers side framerail ,especially the areas of wire that are secured by clips to the frame . it's pretty common that the whole length of wiring is all cracked and dryrotted and shorting out on the frame
Old 07-24-2005, 09:56 PM   #7
355
355's Avatar
Mine did the same thing. Turned out to be the wiring that travels down the frame rail was in contact with the exhaust pipe and had melted the insulation on the wire for the brake circuit. Moved it and taped it and secured it and have had no further problems in 3 years. Oh by the way I found it after tearing my steering column apart. Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 07-24-2005, 11:13 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Try the turn signals... if one of them pops the fuse, then that'll narrow it down as to what wire you'd be looking at.
