Old 07-24-2005, 07:34 PM   #1
git-r-stuck
4x4 fills like sticking
Hi I have a 84 chevy 4x4 it has a 208 transfercase and the problem I am having is when it is out of 4wheel drive adn the front driveshaft is spining free you go around a corner and it fells like it is in 4 wheeldrive slightly. the front will slide but if you put it in 4 wheeldrive will locks in.the front hubs are in the free position.. Thanks any help please.....
Scott
git-r-stuck is offline   Reply With Quote
Old 07-24-2005, 08:22 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Although the hubs are in the free position, they may be sticking and not releasing. If so, they may release if you back the truck up for several feet. If the hubs are sticking, maybe they need to be taken apart, cleaned, and re-assembled with fresh grease.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-25-2005, 01:17 PM   #3
git-r-stuck
Thanks I will try to clean and lube first...
Scott
Old 08-02-2005, 06:40 PM   #4
git-r-stuck
cleaned my hubs ect. It is still sticking.my friend says it is the u-joints so i will replace then... Thanks
Old 08-09-2005, 08:43 PM   #5
git-r-stuck
transfer case
how can you tell if your transfer case is not coming out of 4 wheel high?
Old 08-09-2005, 09:28 PM   #6
ben@speedbarn
Done yet?
ben@speedbarn's Avatar
You should be able to turn the front drive shaft freely if the hubs are not locked in and the transfer case is in 2wd.
'76 k2500 -- almost done...
ben@speedbarn is offline   Reply With Quote
