Old 08-14-2002, 05:54 PM   #1
THOR 50
Over worked under paid
THOR 50's Avatar
Question Stock temp gauge help
Well I got my amp gauge working, Thanks everyone and Longhornmail.
Now working on the stock temp gauge. Bought a new sending unit from NAPA and hooked the correct dark green wire to it. I stiil have my after market gauge as well so I know the engine got hot enough to register. I now get some movement from the gauge but I never moves pased the left most cold tick mark.
Does the pointer come off so I can change its starting point?
How can a test the gauge/is it just shot and if so anyone have a working spare?
Any ideas?
Roger
'69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears
THOR 50 is offline   Reply With Quote
Old 08-14-2002, 06:01 PM   #2
RON WOODGEARD
Resident Young Old Dude !
THOR,
It sounds as if the "RESISTANCE" is off IE: the auto parts store gave you the wrong sending unit.
This will happen on the factory fuel gauge also if it's the wrong sending unit.
RON
RON WOODGEARD is offline   Reply With Quote
Old 08-14-2002, 06:06 PM   #3
THOR 50
THOR 50's Avatar
Thumbs up Sending unit?
Thanks Ron (helping a buddy with his truck). Is the sending unit any different for a 6 or 8 cylinder.
Roger
Old 08-14-2002, 06:10 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
While I don't know the details of the factory temp guage, You can test your guage by grounding that green wire. If it pegs the needle, the guage is working...maybe no acurately, but it'll be working.
Old 08-14-2002, 06:16 PM   #5
THOR 50
THOR 50's Avatar
Thumbs up I'll try that
THANKS! I want to be an ANTI RICER member too can I join?
Roger
Old 08-14-2002, 06:22 PM   #6
RON WOODGEARD
ANDY,
Do you remember what OHM the resistance is on the sending unit and gauge ? I don't.
ROGER,
Check with WES on this I'm sure he'll know. AND thanks FOR THE INFO. ON YOUR GAUGES.
RON
Old 08-14-2002, 06:24 PM   #7
THOR 50
THOR 50's Avatar
Thumbs up Again
Thanks Guys.
Roger
Old 08-14-2002, 06:48 PM   #8
Longhorn Man
It's not a club...just an anti ricer member of this board...
I have no idea on the ohms specs there ron...I have never had to mess with the stock set up...yet.
Old 08-14-2002, 09:37 PM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
idiot light
Sounds like you got a sending unit for a dash light not the one for a gauge. I believe someone else had this problem many moons ago.....
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-15-2002, 12:17 AM   #10
Richard
If you are running a low temp stat like a 160 it probably will not even register on the gauge if your cooling system is working well. My trucks and others I have seen run just past the first mark with a 195 stat when warm. I had infact thought the sending unit was bad on my current 72 when I purchased it. Grounding the sending unit wire confirmed the gauge worked. Replaced the stat with a 195 and installed my new US Radiator 4 row unit and the guage goes up to that point when warm and never moves.
Richard
Old 08-15-2002, 12:24 AM   #11
THOR 50
THOR 50's Avatar
Thanks Richard. The after market gauge in the truck shows consistant 190degrees while idle and when in the highway with the engine running 35 grand RPM it goes to 200.
I tend to think its the wrong sender (for idiot light) but haven't checked the guage by grounding; will do tomorrow and follow up tomorrow night.
Wish someone knew the resistance then I could verify the sender.
Roger
Old 08-15-2002, 05:44 AM   #12
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Sender should be 1 wire type, not 2, 90 ohm resistor should show temp as hottest.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 08-22-2002, 07:17 PM   #13
THOR 50
THOR 50's Avatar
a little more info
Still can't get this right. Grounded the gauge's wire and nothing no movement. So need a new gauge right? anyone have a good one for sale?
Roger
Old 08-22-2002, 07:34 PM   #14
Longhorn Man
Well, it could be a couple things, the green 'ground' wire could be shorted out, or there may be no power going to the guage.
Old 08-22-2002, 07:42 PM   #15
THOR 50
THOR 50's Avatar
Thanks Andy, need to double check grounding the wire with the key ON. that was dumb of me.
Roger
Old 08-22-2002, 07:45 PM   #16
mikep
Used to have a truck
mikep's Avatar
I have a 180 thermostat and water temp is verified 180 degrees with a mechanical gauge. Mine doesnt move off the C either unless it gets hot. You can take the water pump belt off for a minute and see if it starts to get warm. Thats how I figured mine out and I was using a new sender from NAPA too. Original thermostats were 195 so that is where the normal band to the left of the guage is calibrated to. You can either get a 180 sender from something that used an electric guage and a 180 sender ( I dont know what either ) or just use a mechanical guage.
No truck :-(
mikep is offline   Reply With Quote
Old 08-23-2002, 11:08 AM   #17
Michael A. K. G
Just to check, you didn't use Teflon tape on the sender by any chance, did you? That's a no-no for an electrical sender. Use conducting tape or sealant only.
Michael A. K. G is offline   Reply With Quote
