Old 07-25-2005, 07:41 PM   #1
zyggy72
Can't kick the addiction!
Parts F/S
I started Helicopter Flight School a couple weeks ago and its time now to pay off some huge bills I've got and find a new car and park/part/sell (haven't decided yet) my everyday driver: 70 chevy pickup 8ft fleet w/ 350/th350.
To start off, time to clean my truck stuff out of my father's garage and yard!
Reply to this post only, no pm's.
Prices do not include shipping.
Delivery possible within 50 miles for the cost of fuel.
I have pics but they are too large to upload. I can email pics unless someone could resize them for me.
1.) Complete 72 - 3/4ton front end minus the power steering box. The upper control arms are ruff and would need to be replaced. Also included are a complete set of brand new (still in plastic) front wheel bearings and seals for this front end. I bought them just in case and never ended up needing them. $200.00
2.) 72 - 3/4 ton Leaf Sprung Dana 60 full floating rear - needs rebuilt - wheel bearings went. $75.00
3.) 72 - 3/4 ton rear leaf spring front spring mounts. Ground off the rivets and removed the brackets. $25.00
4.) 72 - 3/4 ton leaf sprung rear shock mounts - $25.00
5.) 72 - 3/4 ton rear leaf springs - needs all new bolts and bushings. $40.00-pair.
6.) 72 - 3/4 ton dana 60 rear cups - pretty rough shape - $5.00
7.) 72 - 3/4 ton front sway bar - $15.00
8.) 72 - Right side frame mount exhaust bracket - $5.00
9.) 68 chevy uncut dash in decent shape some small holes drilled in the bottom of dash on the driver side - $35.00
10.) L6 Hei came off a running 250 straight six. - $40.00
11.) 292 L6 Rebuilt head - low miles - $40.00
12.) 292 L6 double groove harmonic balancer - $30.00
Emblems:
13.) Bowtie/20 - has all pins & some paint fade/wear - $10.00
14.) Custom/10 - has all pins - would cleanup nice - $10.00
15.) Cheyenne/20 - has all pins - paint fade/wear & some pitting - $5.00
16.) 8-350 fender badges - paint fade and need to be cleaned up - $5.00
17.) "Chevrolet" emblem - $2.00 each
18.) 67/68 bowties grill emblem - $10.00
19.) 2 pair - 69-72 chevy head light trim rings - very light wear. $10.00 per pair.
20.) 1 pair - 67-68 chevy head light trim rings - light wear. $10.00
21.) 1 pair - 67-68? painted GMC head light trim rings - $15.00
22.) Interior rear view mirror - cab mounted - $5.00
23.) 2 pair of 72 door panels (1 pair - black, 1 pair - med. blue). Both show signs of wear. The med. blue pair have the slots for the woodgrain trim rings and is slightly faded. $15.00 per pair
24.) set of misc. coil spring rear frame brackets - $30.00 all
25.) 3 plastic fan shrouds - all small block 2wd shrouds (one is well used) - $20.00 each for the 2 better ones - $10.00 for the well used one.
26.) L-6 fan shroud - $10.00
27.) Front 2wd crossmember (the one that always gets bent & twisted) - $15.00
28.) 2 pair - upper radiator brackets - $5.00 per pair
29.) 2 vacuum reservoirs - newer "bubble" type - $5.00 each
30.) 2 heat riser choke springs with cover and rods $2.00 each (SOLD)
31.) 72 cab clearance lights wiring harness, un-hacked - $5.00
More parts to come...
I have limited access to the internet, so it may take a day or so to get back to you. I apologize if that is a problem for some people.
zyggy72 is offline   Reply With Quote
Old 07-25-2005, 08:06 PM   #2
70GMCer
70GMCer's Avatar
I'm interested in the "Heat Riser Choke Spring/cover/rod for $2.00. How much to ship to 21085 ?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-25-2005, 08:12 PM   #3
Primered_69
Primered_69's Avatar
I6 Hei. Shipping to 76116.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 07-25-2005, 08:19 PM   #4
arkracing
Weekend Warrior
I'd like to come take a look @ your parts if I could. Interested in a good Small Block Shroud and other parts.
no 5-lug coil spring rears that you know of do you?
Wow ok i posted a reply before I realized how far out you were. I already have a shroud - it's just broken on the lower portion. I still would be interested in a 5-lug rear, StepSide bed Sides, StepSide Steps, maybe you'll have something else when you list the rest of your parts
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 07-25-2005, 08:33 PM   #5
zyggy72
70GMCer - heat riser assembly $8.00 shipping (seems too high)
Primer 69 - L6 Hei $13.50 shipping
arkracing - I do have a 5-lug rear not sure what it is or if its any good. I also have a driver side short bed step that will be going up for sale. The step has a 1.5" stress crack that needs to be welded (was going to do it myself), other than that it in beautiful shape. Not sure what to ask for it yet.
Old 07-25-2005, 08:36 PM   #6
arkracing
Weekend Warrior
Let me know definatly on the rear - send me a PM or email @ arkracing@hotmail.com and I can meet you Monday - Thursday @ anytime really
i'd be willing to pull the cover and look @ it to see if it is any good with you
-'66 C10 Suburban
Old 07-25-2005, 08:37 PM   #7
zyggy72
Another thing that I do have that I'm looking at selling is a 71 Chevy short bed leaf sprung chassis. Its straight and has surface rust and some slight pitting (nothing severe). Was originally a 307 w/ 4 speed. $500.00 obo.
I do not have pics of the chassis as of yet.
Old 07-25-2005, 08:38 PM   #8
Blue_71
Bloo
Blue_71's Avatar
i would be interested in the clearance light harness, shipping quote and pic to 42141 please
smurf_71chevy@yahoo.com
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-25-2005, 08:39 PM   #9
70GMCer
70GMCer's Avatar
Yeh! That's way too high for the shipping on that little thing......I'll pass
1997 GMC Sierra Ext
1965 Mustang
Old 07-25-2005, 08:49 PM   #10
zyggy72
70GMCer - sent pm
Old 07-25-2005, 08:55 PM   #11
zyggy72
Blue 71 - email sent
Old 07-25-2005, 09:16 PM   #12
tomatocity
tomatocity's Avatar
I would like what is on this list.
7.) 72 - 3/4 ton front sway bar - $15.00 - if this is a 1 1/4" and will fit a 1/2 ton 71 frame.Does it come with teh brackets or bushing brackets?
22.) Interior rear view mirror - cab mounted - $5.00 - if it is not smoked or damaged.
28.) 1 pair - upper radiator brackets - $5.00 per pair
29.) 1 vacuum reservoir - newer "bubble" type - $5.00
Also: do you have an unbroken AC housing cover? The piece where the vacuum reservoir mounts? I need one.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-25-2005, 09:17 PM   #13
Blue_71
Bloo
Blue_71's Avatar
im going to have to pass, thanks for your time!
(the harness looks great but the plug-ins wont work with my aftermarket lights)
1989 Chevy K2500
Old 07-25-2005, 09:39 PM   #14
tomatocity
tomatocity's Avatar
go to
http://www.microsoft.com/windowsxp/d...powertoys.mspx and download Image Resizer. This is as easy as easy gets. After you have downloaded and Run the .exe then you will be able to right click on any image and go to 'resize image'. Then you can choose the size you want: small; medium; large; pocket. Thats all folks.
Old 07-25-2005, 09:52 PM   #15
RicksTrucks
RicksTrucks's Avatar
Suggestion: you might edit your first posting as things are sold.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 07-26-2005, 06:46 AM   #16
vtblazer
vtblazer's Avatar
Originally Posted by zyggy72
I do have a 5-lug rear not sure what it is or if its any good. I also have a driver side short bed step that will be going up for sale. The step has a 1.5" stress crack that needs to be welded, other than that it in beautiful shape.
Is that just the 'bed side'? Or a complete bed?
I'm looking for a complete short bed, if you have one.
Interested in the rear coil spring parts also.
What all is included? Just the spring cups or more?
Thanks.
vtblazer is offline   Reply With Quote
Old 07-26-2005, 07:16 AM   #17
I want to buy #21 and #31,if they are available.Going away`til the 1st.Please pm address and shipping cost to 21771,thanks.Leaving early am 27th.
ps:Got pics?
Old 07-26-2005, 08:05 AM   #18
Purs
Got Big Block?
Purs's Avatar
can you email a pic of the rear view mirror to bpursley@esc14.net If it's pretty good I'll take it.
Thanks.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 07-26-2005, 10:50 AM   #19
nu2-72
would like the cab clearance lights wiring. 64504
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 07-26-2005, 05:09 PM   #20
Primered_69
pass on HEI - thanks
Old 07-27-2005, 06:30 AM   #21
I`m off until monday.Please pm info on the GMC bezels and the clearance light harness with shipping.I`ll respond on monday.ZIP:21771
Old 07-30-2005, 02:34 PM   #22
RedBeard
What would shipping be on these two items, to 84057?
RedBeard is offline   Reply With Quote
Old 07-31-2005, 02:41 AM   #23
suville
suville's Avatar
L6 2 groove damper
What is shipping to 98273? Thanks
suville is offline   Reply With Quote
Old 07-31-2005, 07:37 AM   #24
vtblazer
vtblazer's Avatar
Thanks.
Any news ziggy?
Bump for ya.
Old 08-01-2005, 07:11 AM   #25
Hey Ziggy,I`m back.Where did you go?RSVP
