Old 07-26-2005, 01:21 AM   #1
mvpco
punch holes in dash for A/C?
HI All!
Any Ideas on cutting, punching the 2 round,oval holes and rectangle hole in the dash when adding/installing the A/C vents?
thought I would ask before I tackle it.
The Air is working good, now just need to finish the vents. This is the factory setup I took off a 72 with A/C and adding it to a 72 without a/c.
I made the templates from an orig. dash, I marked them on my dash, now just need to cut, punch them out.
Jeff Smith
Pensacola, FL
mvpco is offline   Reply With Quote
Old 07-26-2005, 01:45 PM   #2
john
member #16
john's Avatar
I used a die grinder with a cutoff wheel and dremel tool to cut the center vent and then a hole saw and a rotary file in die grinder for side vents. Took about 20 min. per hole. Tape around the holes with masking tape to keep from chipping paint. Also there isnt too much leeway on the side vents for width. Check often when close to size. John
john is offline   Reply With Quote
Old 07-26-2005, 10:45 PM   #3
71RestoRod
71RestoRod's Avatar
If you have the templates to work from than that's half the battle. I basically eyeballed it... taped it, penciled the outline and used a body saw to cut them out. It easily turned the curve for the outside vent holes. The side holes appear to be oval, but they're actually a circle if you look at them straight on. I drilled four holes to radius the corners of the center vent and then a few more to get the body saw started. Used a die grinder and hand file to finish them up. John is right... tape it up to avoid chipping, test fit often and remember you can always make them bigger if you have to.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 07-27-2005, 08:23 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
what they said except when done send me the templates
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-27-2005, 11:52 AM   #5
724wdcopper
graphic designer
724wdcopper's Avatar
seriously, if you could make those available to others, that would be so killer! i'd like a set, too. any access to a photo copier? i'd give you money for a stamp!
724wdcopper is offline   Reply With Quote
Old 07-27-2005, 11:58 AM   #6
Blue85
Oilfield Trash
Blue85's Avatar
mvpco, Did you use a factory A/C Box? If you did, how did you make the firewal work, in respect to the different hole sizes and locations?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 07-27-2005, 12:00 PM   #7
cwilkie
Chance
cwilkie's Avatar
templates
That would be great if you had some templates to distribute. I need to get the A/C holes cut before it goes to paint. Just to make sure "ever stuff" works.
Chance
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 07-27-2005, 12:10 PM   #8
72GMC51
72GMC51
72GMC51's Avatar
template a/c vent
I have the templates from old air products will post when I get home from work.
JC
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10.
Are they ever really finished
72GMC51 is offline   Reply With Quote
Old 07-27-2005, 12:13 PM   #9
cwilkie
Chance
cwilkie's Avatar
Templates
Great!! When they are posted are they going to be to correct size? Thanks!!!!
Chance
BB 396 w/TH400
BB 496 w/TH400
Old 07-27-2005, 12:36 PM   #10
panhandler62
Java Mechanic
panhandler62's Avatar
I recently saw a number of ac dashes for sale (cheap) on the parts board. That miight be a way to go also.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-27-2005, 03:44 PM   #11
55454
55454
55454's Avatar
The easiest way without cutting up another dash for templates which I have done, cargo light also ( STP has the templates they go back and fourth between us) is take masking tape go over the hole on an a/c dash cut the middle out and put it on the other dash and mark it. Someone, someone knows has to have an a/c dash. If not pm me and I will cut a pattern and sent it on saran wrap. Postage due of course.
Tommy
55454 is offline   Reply With Quote
Old 07-27-2005, 04:48 PM   #12
sleepyboy
'69 Step
I used a hole saw, cut one size smaller than actual hole needed, then dremeled it to size. Tape is a must, along with checking often..
sleepyboy is offline   Reply With Quote
Old 07-27-2005, 05:01 PM   #13
cwilkie
Chance
cwilkie's Avatar
hole saw??
What is a whole saw? Is it that cylinder which was around the perimeter of the cylinder?
Chance
BB 396 w/TH400
BB 496 w/TH400
Old 07-27-2005, 06:24 PM   #14
72GMC51
72GMC51
72GMC51's Avatar
I emailed them to another member and he said they worked great, if you would like I can do the same for you or will snail mail them to you if you want.
that goes for anyone that wants them.
JC
Chance
Old 07-27-2005, 06:33 PM   #15
tom1000
cut and file
That's what I did. I used a rotary file for my cordless drill.
Work slowly so you don't cut too much. The holes don't have to be perfect just enough to insert the AC grilles.
tom1000 is offline   Reply With Quote
Old 07-28-2005, 12:20 AM   #16
Hart_Rod
Hart_Rod's Avatar
Hey Jeff,
Where do you hang out? I'm up in Pace, got a 69 Suburban I "playing" with.
Rob
Hart_Rod is offline   Reply With Quote
Old 07-28-2005, 10:53 AM   #17
farside847
farside847's Avatar
That looks like a nice spot to hide some speakers actually, Hmmmmmmm.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-28-2005, 08:47 PM   #18
86swb
Born a Chevy Man
86swb's Avatar
JC
I plan on putting air in my '70 and would like a set. I sent you a pm with address. Thanks
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 07-28-2005, 09:04 PM   #19
RED71CHEVY
RED71CHEVY's Avatar
i am putting a "vintage air" in mimy 71 c-10, i bought the factory style ac side vents from them , but all they sent me for a cut out pattern is for their small ac vents .......... so i would really be happy for a set of your patterns for the factory style side vent cut outs!!!! you can email them to me at: tlewis37@sc.rr.com
thanks in advance.
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 07-29-2005, 11:52 AM   #20
/<eystroke
/<eystroke's Avatar
Here is my copy of the ac vent templates.
'69 C/10 Short Wide
350/400/AC/Tilt/Tach
/<eystroke is offline   Reply With Quote
Old 07-29-2005, 01:34 PM   #21
2low72
Yep!!
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 07-29-2005, 03:33 PM   #22
mvpco
Originally Posted by Hart_Rob
Hey Jeff,
Rob
Great!
I am off Olive Road, between 9th Ave and davis Hwy.
3519 Gatewood Drive
Pensacola, FL 32514
475-5030
324-1713 Cell
if you want to look it up on Yahoo Maps or Map quest.
I have some extra stuff (power steering pumps, radio etc) if you need
Do you have A/C in yours?? I would like to look at it!!!!!1
Jeff
Old 07-29-2005, 09:36 PM   #23
mvpco
Duct Hose for left and right vents A/C
HI All!
Ok.... I tried to hook up the damn duct/hose to the side vents and just about /8 to 1/4 to small (I odered a set off Ebay some time ago).
Question: is there a special type duck for the left and right side vents on the dash? and who has them and phone number and part number please.
They set I bought are just like the defrost hose but alittle bigger.
I tried locally but only sizes are 2 1/2 and 3 inch, I measured miy vent where it hooks up and it is 2 3/4 inch doh!!!!
Jeff Smith
Pensacola, FL
Old 07-29-2005, 09:53 PM   #24
sleepyboy
'69 Step
Chance
A hole saw has a drill bit in the center with a metal cylinder that surrounds it. The drill bit keeps your center bore. It is used for a variety of applications, like sawing holes for locks in wooden doors, etc. Home depot/Lowes, around $25. I don't exactly remember, bot you need 2 1/8 or 2 1/4??
Old 07-30-2005, 09:08 PM   #25
mvpco
duct hose to a/c vents?
HI All!
I ordered a complete duct hose A/C & defroster set and all fits fine except for the 2 that go to the 2 side A/C vents. Just to damn small(hose/duct) I measure about 2 3/4 inches and the duct that comes with the kit is just over 2 1/2 inches. any ideas on this or where to get the correct hoses/ducts for the A/C vents?
Jeff Smith
Pensacola, FL
850-475-5030
