07-27-2005, 10:52 AM | #1 |
Back in the sticks
Need Opinions: Which Headers?
Started putting on the stock mainifolds yesterday and they are warped beyond use. So, I need your opinion on which headers to use. Dynomax coated long tubes, or block huggers? The long tubes will require removing and reinstalling the clutch linkage, while the block huggers will slip right in. Any pics would be great too. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
07-27-2005, 03:26 PM | #2 |
The LuvShack Garage
On the Blazer or your P/U ?
I'm assuming the Blazer, well you know what they say, everyone has an opinion and they are entitled to it, I used a mid length on "GQ" (And no they are not chevelle headers) lots of pic's in linky within my sig, page 15 I think, I could not be happier with mine, I wanted to be able to run my pipes over the transfer case area without using extreme bends on my exhaust, with these headers everything is tucked up in there, pages 16-18, You can get them from JEGS or Summit, they are HEADMAN "ELITES", they do have the ceramic coated finish, ball flanges (leak less) & much thicker flanges on the head side also, I was very impressed with them HEADMAN ELITE CERAMIC COATED HEADERS SUMMIT - #HED-69830 JEG'S - #500-69830 $274.XX DELIVERED TO MY DOOR FROM JEG'S THESE ARE FOR 4WD BLAZERS ONLY, WON'T FIT 2WD
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
07-28-2005, 11:46 AM | #3 |
Back in the sticks
Yep I meant the Blazer Luv. Those look nice. I think I would have to remove the clutch linkage to get them in and out too. Looks like the downtube for nuber 7 cylinder is in the same place as the long tubes. Thats why I was wondering about the block huggers. They'll clear the motor mounts and not interfere with the linkage if I run the connection to the collectors below it. Any other opinions out there?
07-30-2005, 09:35 AM | #4 |
Heddmans. IME, they were the only ones who make a header that will work with the stock clutch linkage. "Some slight modification" to the linkage specified by the other headers I tried meant moving the fram bracket over 2" and shortening the rod.
I ditched my headers and 2 1/4" exhaust for factory 2 1/2" 'vette manifolds and 2 1/2" exhuast with Dynomax Hemi Turbo mufflers (20" case). This is one of best mods I have done to truck and would still recommend it even though manifolds are now $125 each.
07-30-2005, 11:32 AM | #5 |
I went with the Hedman Headers when I switched over to the SM465, because it cleared the clutch linkage. But I did have to grind about 1/4 inch off the passenger side frame rail for comfortable clearance. I went with the bottom of the line, no coating, no chrome, I have been happy with them. I will try to get a pic up soon.
07-30-2005, 02:42 PM | #6 |
Good info guys, happen to have the hedman p/n? MikeC, what you did is what I'm thinking of doing, but didn't realize the manifolds were that expensive. Haven't really seriously looked into it since I'm not at that stage yet. I've read that the ram horn manifolds are just as good as going to headers for rigs that are more for torq than HP and top speed.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
07-30-2005, 03:50 PM | #7 |
Premium Level Member
I'm running hedman's 69234 in both my 69 and 77 with no clutch linkage or frame problems. They are also C.A.R.B approved for use in California(needed for my 77 k5)
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
07-31-2005, 09:50 AM | #8 |
I've had my Heddmans since 1990. they would still be fine with slip on collectors, but the flange has rusted where they won't seal with the 3 bolt gasket.
GM has discontinued the manifolds. They are still available, but price has gone from $75 each when I did mine in 2000 to $125 or so. I just bought a new fuel pickup for my Camaro. In my '03 catalog, the OER reproduction and the GM were both $59. Now the OER is $59 and the GM $159! GM's pricing may make money, but they really need to think about customer retention as a positive for their business model...
07-31-2005, 08:13 PM | #9 |
Back in the sticks
Thanks for the input guys, sounds like the Headmans are the way to go. I like regular headers better than the block huggers anyway, just needed to make sure I cleared the clutch linkage. Jeff.
