Old 07-31-2005, 05:53 PM   #1
rage'nrat638
rage'nrat638's Avatar
how do i find out what rear end i have
71 chevy 3/4 ton.......just bought to part out ......how do i do this???????
thanks for the help.......
rage'nrat638 is offline   Reply With Quote
Old 07-31-2005, 06:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What shape is the rear cover?
If it is round, like a salad bowl, it's an HO52. A corp rear with an Eaton diff in it.
If it looks like a dana...it's a dana.
Old 07-31-2005, 07:29 PM   #3
krue
Designated A-hole!
krue's Avatar
Look in the mirror.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-01-2005, 12:53 AM   #4
SK1970
Active Member
get the id# off the axle tube it should be on the bottom of the tube and post the number and I will tell you what you have.
SK1970 is offline   Reply With Quote
Old 08-01-2005, 01:06 AM   #5
shifty
Questionable
shifty's Avatar
Bend over, spread your cheeks and look in the mirror. LOL
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-01-2005, 02:05 AM   #6
Alaskan
Truck'n the alcan
Alaskan's Avatar
Ho72
My 71 C/20 has an HO72 stump puller.
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 08-01-2005, 05:34 AM   #7
Longhorn Man
Alaskan, why do you say you have the HO72? 3/4 ton trucks only got the HO52.
Old 08-01-2005, 05:35 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have a dana 60 in my garage that came out of a 71 C20 w/ leaf springs, was 4.10 ratio. Does it look like this in shape?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-01-2005, 01:54 PM   #9
96blazr
96blazr's Avatar
I was wondering about this too. I just crawed under there Sunday and wrote down the only info I could find.
It says: "GM55"
There is a series of numbers on the axle tube, but it only says:
Top row:"1 2 3 4 5"
Under that it says: "6 7 8 9 0"
I tried looking everywhere on the Pumpkin and all around. Did I not look close enough?
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 08-01-2005, 08:48 PM   #10
larry may
There is a number on the right side axel tube. It is stamped on the front side of the tube near the center section . I am needing same information you are after. Posted earlier today. Sure could use some help here.
larry may is offline   Reply With Quote
Old 08-01-2005, 09:10 PM   #11
byrd
Union Electrician
byrd's Avatar
Mine is round like you say,and is a 12 bolt does that mean it is the corp rear end? Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 08-01-2005, 09:23 PM   #12
Longhorn Man
Yup. If it is 3/4 ton or one ton, and has the full floating axles (pop the hubcaps off, and see if it has a huge hub pokin out of the center of the wheel with 8 or so bolts) then yes, it'll be an HO 52 or HO72 (one ton) eaton/corp rear end.
Old 08-01-2005, 09:37 PM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The 12 bolts hold the ring gear and carrier halves together, there are 10 bolts holding the cover on and 10 bolts holding the third member on.
Old 08-01-2005, 11:15 PM   #14
drink2mny
drink2mny's Avatar
Is it one of these??
top is the eaton.
Dana 60 I.D.
Support The Board
drink2mny is offline   Reply With Quote
Old 08-01-2005, 11:16 PM   #15
drink2mny
drink2mny's Avatar
Dam thats a big rear end...
Support The Board
Old 08-02-2005, 01:40 AM   #16
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
You sure got a big rear end, Jon.
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 08-02-2005, 01:42 AM   #17
drink2mny
drink2mny's Avatar
I knew you were checking me out at the swapmeet... Why don't you call like you use to???
Sorry Rat, had to respond....
Support The Board
Old 03-28-2016, 02:29 AM   #18
SonomaComa
Re: how do i find out what rear end i have
What rear end is that in the picture?
I have the same rear end in my 1970 GMC C20. 8-Lug, 1/2" Studs. On the top right hand side above the Dif cover it has the same code stamped upside down of C-30255, and on the bottom side of the Dif cover it has the number 60
SonomaComa is offline   Reply With Quote
Old 03-28-2016, 02:39 AM   #19
SS Tim
SS Tim's Avatar
Dana 60
SS Tim is offline   Reply With Quote
Old 03-28-2016, 02:49 AM   #20
SonomaComa
Originally Posted by SS Tim View Post
Dana 60
Right on, thank you. My truck is a 2WD and on the Front it has Spindles from a 1972 Chevy for the front disc brake conversion. But those Wheel Studs are 9/16" and on the Rear Hubs they are 1/2" Wheel Studs. Hopefully I'll be able to purchase new rear hubs with 9/16" Studs.
Or will I have to have them drilled out....?
