Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 08-02-2005, 09:03 AM   #1
motocrosschump
Engine Degreaser?
What kind of Degreaser/and or method to remove stuck on grease in order to prep drivetrain for paint
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 08-02-2005, 09:07 AM   #2
Yukon Jack
Yukon Jack's Avatar
For mine I went in steps. First I power washed the block, then I used some oven cleaner, then Castrol Super Clean along with some (okay, lots of) scraping and brushing with an old toothbrush. Finished with lots of rinsing with Lacquer Thinner to get it ready for paint.
Don't get the oven cleaner near the seals or anything aluminum.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-02-2005, 10:35 AM   #3
matthufham
choke/carb cleaner from auto-zone and a wire brush
matthufham is offline   Reply With Quote
Old 08-02-2005, 10:59 AM   #4
tomatocity
tomatocity's Avatar
Agree with Yukon Jack though I also use Degreaser from Costco. Tough stuff and you might want to consider using rubber gloves. I run a hose from a hot water outlet to help with the really greasy stuff.
In the final stage you can use paint thinner in a paint gun or a high pressure sprayer.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 08-02-2005, 12:21 PM   #5
HuggerCST
HuggerCST's Avatar
Oven cleaner. A couple of applications of good oven cleaner will save alot of scraping, and will even remove the old paint.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 08-02-2005, 02:58 PM   #6
xtremer-pxl
xtremer-pxl's Avatar
thats what I use..it works great. cheap stuff from walmart!
WANTED 2dr 4x4 fullsize blazer, yukon, tahoe
South Central Kansas Member
xtremer-pxl is offline   Reply With Quote
Old 08-02-2005, 03:19 PM   #7
chevyfarmer
chevyfarmer's Avatar
If you know anyone that has a hot water power washer, it will save you some time. I hauled my 454 motor to a friend house that had one, and it turned out almost clean enough to paint. Good Luck.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 08-02-2005, 03:42 PM   #8
bowtie
bowtie's Avatar
I just bought a pressure washer (no hot water though) because I was tired of hauling everything to the car wash or golf course shop to clean the parts. The oven cleaner sounds like a good idea.
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
