Old 08-02-2005, 10:31 PM   #1
Truckhead
18436572
Truckhead's Avatar
Aftermarket Trans crossmember
I'm installing a TPI motor and 700R4 in my 70' C10 2wd Short. The stock crossmember just won't seem to go back in. I will be bagging my truck in the future so can you guys recommend an aftermarket crossmember to work?
Thanks.
Any other tips for this install would be helpful.
Truckhead is offline   Reply With Quote
Old 08-02-2005, 10:36 PM   #2
Truckhead
18436572
Truckhead's Avatar
I'm looking at the ECE crossmember but i wanted to check here first.
Old 08-03-2005, 06:39 PM   #3
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
all i had to do was slide the motor foward about 1/4 inch...the holes in the motor mounts were elongated so this was not a problem.....and put my stock x-member in the th400 location...then everything bolted right up.
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 08-03-2005, 06:41 PM   #4
sixty8c10
sixty8c10's Avatar
the motor mounts i'm taliking about are the ones that bolt from the frame to the x-member the 2 holes in the top on the frame are elongated.
Old 08-04-2005, 03:55 PM   #5
72MARIO
72MARIO's Avatar
I used the stock one with my 700R in the 8 and 6 cyl position. You may have to drill new holes in the frame but it will work even with a bagged truck. The ECE or CPP and Brothers crossmembers are all the same. I have seen it in a local shop here looked good but why spen the money if yours will work ? Be sure to install the stocker with the slope back not towards the front.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
