Old 08-03-2005, 06:55 PM   #1
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
frame dimension?
does anyone know of the differences between an 82 chevy swb frame and the frame of a 88 k-5 blazer? or know of a website that has this info?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 08-04-2005, 12:43 AM   #2
bodydropped
the k5 is alot shorter i seen a guy put a truck cab on the k5 frame and narrow the bed alot and i got 2 trucks like this at work one is a 2wd the other is a 4x4 but there been out back at work for years ill try and get a side shot for u
bodydropped is offline   Reply With Quote
Old 08-04-2005, 12:06 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
LOTS K5 wheelbase is 106.5" a C/K10 wheelbase is 117.5"
This is a SWB C10:
This is a '82 K5 2WD: 4x4 will have taller spring perches in back and there will be some in front. The frame rails will be the same though.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-04-2005, 04:56 PM   #4
sixty8c10
sixty8c10's Avatar
the reason i ask is cause i want my blazer to be 2wd and my p/u to be 4x4...just thought that maybe i could swap frames.....guess not. but i can swap suspensions.....hardest part is changing the front to 2wd
Old 12-01-2017, 07:11 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: frame dimension?
I know this is OLD, but ...
Can you (or anyone) confirm that the frame and springs are the same and just the perches are different... I am trying to figure out if a FACTORY 2WD Blazer from is the same as a C10... FROM The FRONT perch of the rear springs... Are the holes in the frame in the same location for the front perch?
Does anyone have some frame diagrams to compare>>>>>
1978 C10 SWB
1978 K5 Blazer 2WD
Rich
1972 K5 Blazer CST Click HERE
Old 12-01-2017, 11:22 AM   #6
Captkaos
Captkaos's Avatar
A pickup frame and a Blazer frame are completely different. Pickup frame is longer and in the rear narraower. The only thing that is the "same" is from the front cab mount forward.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-01-2017, 11:24 AM   #7
Captkaos
Captkaos's Avatar
See here for dimensions
http://forum.73-87chevytrucks.com/sm...?topic=21682.0
Chris Lucas
1973 Chevy C-10
Captkaos Customs
