Old 08-04-2005, 03:30 PM   #1
Truckhead
18436572
Truckhead's Avatar
WTB: front crossmember
If anyone has an already modded front crossmember to lay rocker or frame for a 70' 2wd C10 forsale let me know. I can use my stocker for a core if needed.
Truckhead is offline   Reply With Quote
Old 08-04-2005, 07:45 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I can build you one if you are interested. It would take about 4 weeks from the time I get it.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-05-2005, 03:27 PM   #3
Truckhead
18436572
Truckhead's Avatar
What would be left to on my part after you mod the crossmember?
Do you think i might need to notch the frame for the steering?
I've got the ECE 4/6 drop with their disc conversion on the truck if it matters.
Old 08-05-2005, 05:46 PM   #4
Jaredm82
Active Member
Jaredm82's Avatar
contact Jeff at KRZ customs... he will section it for you for 100 bucks. Atleast 2-3 years ago thats what he was going to do it for me for. And yes, you have to raise your steering linkage up as much as you section your cross member to keep the right geometry. Then notch your frame accordingly.
Jaredm82 is offline   Reply With Quote
Old 08-05-2005, 06:48 PM   #5
Captkaos
Captkaos's Avatar
You might want to check this thread, it has everything listed that is required.
http://67-72chevytrucks.com/vboard/s....php3?t=137398
You will need to modify the steering linkage, (borgensen joints) and notch a few places for clearance on the crossmember. (see above) As for notching the frame for clearance, not unless you go more than 1.5".
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-06-2005, 04:31 PM   #6
Truckhead
18436572
Truckhead's Avatar
Thanks, this swap shouldn't be that hard from the looks of it. (famous last words)LOL
Old 08-06-2005, 08:14 PM   #7
XXL
Seņor Member
XXL's Avatar
I don't know anything about KRZ Customs, but for the amount of work Captkaos did for mine, KRZ'd probably be making minimum wage
After all the dust settled, my front notch cost me < $2k. That's rounding up an xmember, Captkaos mod, shipping both ways, new bags and plates, new ART control arms, Borgeson parts, and some labor. Subtracting the ART control arms would put everything < $1k.
XXL is offline   Reply With Quote
Old 08-07-2005, 03:29 AM   #8
Jaredm82
Active Member
Jaredm82's Avatar
he was just asking about getting a crossmember cut, welded back together, done. I don't see why it'd be so expensive...?
Old 08-07-2005, 09:11 AM   #9
Alvin
Never Done?
Alvin's Avatar
He did ask a little more than just about the x-member.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 08-07-2005, 09:36 AM   #10
XXL
Seņor Member
XXL's Avatar
Originally Posted by Jaredm82
he was just asking about getting a crossmember cut, welded back together, done. I don't see what the extra $900 you spent was for? That sucks for you man
I'm one of those idiots who likes the job to be complete and correct. See, buying a gas hatchet doesn't make you a suspension expert. But thanks for the comment nonetheless.
Old 08-07-2005, 12:30 PM   #11
Jaredm82
Active Member
Jaredm82's Avatar
"If anyone has an already modded front crossmember to lay rocker or frame for a 70' 2wd C10 forsale let me know. I can use my stocker for a core if needed." the original question is what I was reffereing too
Old 08-07-2005, 03:37 PM   #12
Captkaos
Captkaos's Avatar
He is probably just cutting the frame sections out using Bill Turners Templates if he is just going to charge $100 (and that is still cheap). But if you do it this way, you are going to have to get someone to chop the engine stands down and verify the clearance for the oilpan/harmonic balancer.
For the amount of work I have to do to eliminate all of these problems where you just have to have a crossmember and everything that was there before (minus steering section) to bolt up, I actually could charge more.
It sounds easy when you say it, but there is a little more to it than that. Here is how my process basically goes: http://www.captkaoscustoms.com/chopcross.html
I wouldn't cut one for just $100, the core cost me almost that much.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-07-2005, 06:57 PM   #13
Jaredm82
Active Member
Jaredm82's Avatar
nope, you bring him your crossmember, he sections it just like all you guys are reffering to here. Take a 1.5" section out of the whole crossmember, weld it back together and make it look nice all for $100. And no he is not using anyone elses stuff. He makes everything in house and does his own machining. Check out his website, asyou will see, he does very nice work. I guess I should just keep my sauggestions to myself
Old 08-07-2005, 09:31 PM   #14
DM310
Hell, that seems cheap to me. I did my own and I know if I did it again I would charge a hell a lot more than $100. Sounds to me like it would be a halfass job for $100. Just fyi, plus captkaos has a good rep on this forum and can be trusted.
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 08-07-2005, 11:57 PM   #15
Captkaos
Captkaos's Avatar
$100 is cheap, if you can get it done for that, well....
BTW, I charge $385 for this plus shipping and core charges for comparison. This is about the same Turners charged for his setup, but you WILL get it, as turnaround is 4 weeks depending on who supplies the core.
Thanks for the Props XXL and DM310.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-08-2005, 04:32 PM   #16
Truckhead
18436572
Truckhead's Avatar
It may cost me, but i want it done right the first time as it'll have to hold up to constant use. Probly as a daily driver, something to haul my Busa to the track and parts hauler for my motorcycle business.
I've seen WAY to many hacked up air suspensions in the past at shows. Some setups make you wonder how they were even being driven without falling apart. For the guys that take the time to do stuff right, my hats off to ya.
Old 08-10-2005, 12:14 AM   #17
qksilver
Use a fat man fab front end, comes with rack, complete suspension and bags. Lays frame, tucks the wheels in, gives major clearance and saves about 100 lbs up front.
A buddy of mine started with the cut cross member and all the other stuff, then sold that and did the fat man swap. easy, steers and drives great and bolts in
just my one penny's worth plus cleaned up the look of the front end with the polished a arm's
qksilver is offline   Reply With Quote
Old 08-10-2005, 11:26 AM   #18
XXL
Seņor Member
XXL's Avatar
Yes, but Krazy somethingorother can do it for $100
Old 08-10-2005, 11:30 AM   #19
GenIIIShorty
JUNK COLLECTOR!!!!!
GenIIIShorty's Avatar
supposedly so, but they don't answer emails
baby
The dark side! 2000 XLT PSD F-250 4x4! Offroad package
1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3
GenIIIShorty is offline   Reply With Quote
Old 08-10-2005, 12:20 PM   #20
1low1967
1low1967's Avatar
I'm going to get flaq for this but why dont you consider "z"ing the frame. All the steering stays the same and if ur not going to run a big wheel u won't need to z it that much. That's just something else to throw at ya
1low1967 is offline   Reply With Quote
Old 08-10-2005, 01:25 PM   #21
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
I called Jeff at KRZ customs and he says he doesn't do the X-members anymore.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-10-2005, 01:45 PM   #22
XXL
Seņor Member
XXL's Avatar
Not enough demand at that price
Old 08-10-2005, 06:31 PM   #23
Jaredm82
Active Member
Jaredm82's Avatar
well like I said, 2-3 years ago I got that price. I was just throwing it out there...
Old 08-11-2005, 12:30 PM   #24
camaro__thunder
I didn't mention a price to him, just asked if he did them, and the answer was no. Anybody else do them ?
My Project 69 SWB
Old 08-11-2005, 02:45 PM   #25
Jaredm82
Active Member
Jaredm82's Avatar
by the way, where is everyone located?
