Old 08-04-2005, 08:13 PM   #1
Hart_Rod
Hart_Rod's Avatar
Scccooooooorrrrrrrrrreeeeeeeee!!!
Just got my new body bushing kit from Energy Suspensions (ordered through Summit part #3-4149). They come in red or black and were only $115 shipped, complete with all hardware!!!!!
Hart_Rod is offline   Reply With Quote
Old 08-04-2005, 10:26 PM   #2
doc70sub
doc70sub's Avatar
Just ordered mine....presently backordered until September.
Thanks!!
Doc
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 08-04-2005, 10:38 PM   #3
newin72
sweet! for the suburban!?!? no way!
thanks!
newin72 is offline   Reply With Quote
Old 08-04-2005, 11:36 PM   #4
cornutz
All Praise RANDY!!
cornutz's Avatar
Did you have to order over the phone?, I cant find it online at all?
HEEEEELLLLP!
NutZ
cornutz is offline   Reply With Quote
Old 08-04-2005, 11:40 PM   #5
cornutz
All Praise RANDY!!
cornutz's Avatar
Ok, I found it, but what part # is the red set? is it ens-3-4149g or is it ens-3-4149r....?
Old 08-04-2005, 11:47 PM   #6
cornutz
All Praise RANDY!!
cornutz's Avatar
Hey, Jegs has it too for $106.99 might be cheaper TO you from them as well...
part #355-3-4149R
Sweeeeeeeeeeeeeeeeeeeet!
Old 08-05-2005, 02:34 AM   #7
kbeefy
kbeefy's Avatar
g is black and r is red
70 k20 'burban (latest aqusition)
91 k1500 xcab lb
99 f350 (sold)
83 cj7 (huge and for sale)
82 rx7 (auto-x project)
74 VW superbettle
04 summit 800 151 & 05 renegade 600
guns, flying, camping, biking, 4-byin, bbq's and beer!
kbeefy is offline   Reply With Quote
Old 08-06-2005, 03:04 AM   #8
4x4Poet
The "g" should also stand for graphite impregnated (in a black color). Should cut down more on squeaks.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-06-2005, 08:36 AM   #9
Hart_Rod
Hart_Rod's Avatar
4X4,
Do you think the red will squeak more?
Rob
Old 08-07-2005, 05:43 AM   #10
4x4Poet
I should have said that the graphite is designed to reduce any squeaking. I haven't tried poly body mounts (red or graphite) on a 2wd, so I don't even know if they squeak if lubed a little when installed on a 2wd. 2wd frames don't suffer the movement 4x4 frames do or leaf-spring, A-arm, trailing arm, or swaybar bushings do, so if the poly mounts will squeak, it can't be much. Poly body mounts can squeak, but I know that as a 4x4 concern off road when the ladder frame flexes more than a 2wd frame does on road.
Is it worth the shipping to exchange? Can't say I know for a 2wd. I would recommend it for a 4x4 if the budget allows, but that's just my opinion. And I strongly recommend graphite impregnated poly for suspension locations. Lube, too. For instance, on my Land Cruiser, I have graphite poly spring bushings with greasable shackles and spring hanger pins that are quiet. The latter two are items 2wd truck users don't normally use though A-arms often have bushing grease points. Before that I just had red poly spring bushings and they did squeak, but that's suspension apples and body mount oranges. Just as unlike with 4x4 trucks, frame twisting is not usually a 2wd concern.
So, I think I made my above post from my 4x4 perspective. Sorry about that. I sometimes forget that most board members are 2wd truck owners.
