Old 08-06-2005, 09:33 PM   #1
skokie
skokie's Avatar
Radiator Support Clip
What are the clips called that go onto the radiator hold downs and where can you get them?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 08-06-2005, 09:55 PM   #2
57sailplane
57sailplane's Avatar
not sure what and were you are talking about. give more description please.
57sailplane is offline   Reply With Quote
Old 08-06-2005, 10:12 PM   #3
skokie
skokie's Avatar
This is a clip that goes onto the end of the radiator hold down brackets that bolt down to the rad support of the truck.
68 build thread
Old 08-06-2005, 10:25 PM   #4
skokie
skokie's Avatar
After doing some digging it looks like its called a j-nut. I called hardware stores around my area and they dont have any. Does anyone know where I can find these?
68 build thread
Old 08-06-2005, 10:28 PM   #5
kaycee
kaycee's Avatar
NAPA had some I'm sure any reputable auto store will have them
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-07-2005, 06:17 AM   #6
4x4Poet
You mean the J-nuts that the bolt/screw holding the fan shroud to the radiator brackets screw into?
Those are available thru 67-72 vendors (as are the hex head bolts/screws), but you might source them at a hardware store since they are just regular J-nuts. Just take the shrould holding bolt/screw with you.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-07-2005, 11:53 AM   #7
57sailplane
i have heard them called a body clip or sheet metal fastener. napa does sell these. most napas have to order them. they are a comon piece used in many areas in the older cars and trucks. now they are plastic of a differant style.
Old 08-07-2005, 11:59 AM   #8
Cheesewagon
Cheesewagon's Avatar
I have a bunch of those (good used) w/ bolt if you need some. Give a PM if you want some. Latter cheesewagon.
'91 suburban 350 TBI - R 700 4 new daily driver
'72 Cheyenne Super 49,000miles 350/350 frame up resto w/ matching numbers.
Cheesewagon is offline   Reply With Quote
Old 08-07-2005, 02:52 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
...also called tinnerman nuts.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-08-2005, 03:04 AM   #10
70c10
67-72 Addict!
70c10's Avatar
I have bought them at Home Depot and Lowes in the hardware section. They are in the wide pull out drawers.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
