Old 08-07-2005, 10:15 AM   #1
Frizzle Fry
Frizzle Fry's Avatar
Small Tank?
My needle goes from full to empty and when I fill it; it only takes 15 gal!!! I've watched carefully to be sure the needle is sweeping fully across the gauge and it goes from past the F to burried in the E and still it only takes 15. I thought these tanks were more like 25 or 27 gal? If the float arm was bent, I would think it wouldn't reach one end or the other on the gauge. Maybe the sending unit was replaced with the wrong ohmage? ...or did some of these have 15 gallon tanks?
Frizzle Fry is offline   Reply With Quote
Old 08-07-2005, 02:34 PM   #2
Hart_Rod
Hart_Rod's Avatar
Mines the same.
Rob
Hart_Rod is offline   Reply With Quote
Old 08-07-2005, 04:15 PM   #3
bagged91
Out draggin'
bagged91's Avatar
Mine takes approx. 18 gals to fill. Cost me $48.60 to fill up on Friday
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 08-07-2005, 09:27 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
When my needle hits the empty mark it takes 15 gallons to fill. If I drive another 50-75 miles it will usually take 20 gallons. The factory tank is 20-21 gallons plus a little more in the filler neck.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-08-2005, 12:14 PM   #5
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
i agree, my truck has a 21 gallon tank and i have even pursued trying to find a larger capacity tank aftermarket and none seems to be available. when you have 4.56 gears offroading is limited to about 100 or so miles unless you carry reserve fuel in gas cans
Superron21 is offline   Reply With Quote
Old 08-08-2005, 01:28 PM   #6
Frizzle Fry
I bought a "Blazer/Suburban" tank off a Military surplus store on eBay for my stepside. They said it was for desiel military Blazers. It was NOS and 27 gallons. It seems to take over 20-23 every time it's on E.
Old 08-08-2005, 01:35 PM   #7
Superron21
Superron21's Avatar
do you remember the stores website URL?
Old 08-08-2005, 03:58 PM   #8
Frizzle Fry
No, they're probably out by now anyway. Those things were going fast! The one I got looks EXACTLY like this one. They called mine a 27 gallon though. 25 seems like it's probably more accurate. I had to replaced the filler neck and modify my truck sending unit to work in it.
You might be able to make this one fit...
Old 08-08-2005, 04:03 PM   #9
Brewski*
Brewski*'s Avatar
Wow my burb holds somewhere like 40 gal. everything in the vehicle is stock but was custom ordered with lots of extras and the gauge works great. I will have to fill it soon again. I will let you all know for sure how much it takes.
Brewski* is offline   Reply With Quote
Old 08-15-2005, 07:17 PM   #10
fde2blk
see my post to others w/same Q
fde2blk is offline   Reply With Quote
