what size bolts for tranny to engine block?
I have an 87 K20 (which happens to have an early 70's frame and axles), and I'm sticking in a fuel injected 350, mating to a TH400. I don't have the bolts that go through the bellhousing into the block, and want to be sure they're not too long (or too short). Anybody know how long they are supposed to be? It's not 100% where it needs to be, so I plan on using the bolts to finish lining everything up. The guide pins are almost in place, but there's about 1/4 to 1/2 inch of space between the block and the bellhousing right now. I still have to bolt up the torque converter and flexplate too, anybody know what size and length bolts I need for that? Should I use split lockwashers on the flexplate/torque converter? Thanks very much for any help you guys can provide!
Crosby 1978 Chevrolet K10 stepside NH |
i believe 2 1/2 should work but put a smaller diameter bolt through trans and in to the block hole see how deep it goes and go from there
torque bolts no washer just raw balls and torque and thread lock
square body trucks an addiction or an investment either way they consume all my extra time and money |
That's a good idea, thank you.. off to the hardware store
Right turn Clyde
It wouldnt hurt to use washers. I would if it was mine.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
california fill
I agree w/ mylilbowtie.... I use lock washers on my bellhousing bolts.. keeps from scarring up the aluminum trans, too...
yeller
I just bought new bolts for my setup, and IIRC, I purchased 1 1/2 or 1 3/4" bolts. I believe they are also 3/8" threads too. Don't take this as gosphel, I have a bad memory...but I am pretty sure about the length.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
