Old 08-17-2002, 03:45 PM   #1
nroden
nroden's Avatar
Tranny Sealer
My original TH-350 seems to have some small leaks. It does shift great and everything though.
I bought some stuff to put into my transmission to stop the leaks that I plan on putting in once it got back from getting painted.
It is SNAP Automatic Transmission Sealer & Condtioner. Any experiences with this? Good? Bad? Put it in or not?
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 08-17-2002, 05:00 PM   #2
Zkast
Zkast's Avatar
Well, remember the old saying " There is no such thing as a mechanic in a can"? Same holds true here.
If you have a transmission that the seals are starting to dry up or shrink (age), this type of additive may help temporarily but your first step should be finding out exactly what is leaking. If its a shift shaft or tailshaft seal... REPLACE THEM. If its a front pump/torque convertor seal you might try that stuff. I doubt its going to hurt anything. Other leak would be the pan gasket, obviously change the filter/gasket at that point.
Zkast is offline   Reply With Quote
Old 08-17-2002, 09:43 PM   #3
nroden
nroden's Avatar
Yeah. I just replaced the filter and gasket last summer. I think I may do it for a temporary fix and see if it works until I get around to it bein it probably can't hurt anything.
Nick Rodenberg
Old 08-17-2002, 09:58 PM   #4
Zkast
Zkast's Avatar
If you'd like, swing by the house on your way back from Paola and we'll have a look at it, or you can come by the shop (151 & Antioch)
Old 08-19-2002, 06:15 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
There are lots of little O-rings and seals that you can easily replace on transmissions and are easy to do. Most cost like .50 cents too!
I'd replace every one you can find and recheck for leaks again.
I don't think any sealer in a bottle will work.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-19-2002, 11:12 AM   #6
nroden
nroden's Avatar
Well I will see if I can see whats leaking when it gets back and see if I can fix it if its fairly easy.
Nick Rodenberg
