Old 08-13-2005, 01:35 AM   #1
mrwilmoth
best front suspension?
I want to upgrade my suspension in the front. what should I be looking for? I want about a 5" - 7" drop.
thanks alot
mrwilmoth is offline   Reply With Quote
Old 08-13-2005, 01:49 AM   #2
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
bags & drop spindles
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 08-13-2005, 04:07 AM   #3
mrwilmoth
ok so drop spindles in the front with 3" lowering springs?
then coilovers in the rear?
not looking for bags. thanks
Old 08-13-2005, 09:32 AM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I'd go with 2" drop spindles from McGaughy's or Early Classic (ECE) and 2 or 3" drop springs, but with 3" drop springs up front and being static that's pretty low. In rear you can get 5" drop springs. Any more than that and you'll have no travel left. axles gonna be on the frame. Gonna need to notch.
67Fleet is offline   Reply With Quote
Old 08-13-2005, 10:19 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Are we talking 63-72 truck here?
I always do a 2.5 inch spindle and a 2 inch spring in the front for 4.5 total. No problems with alignment or rubbing and it will still ride fine.
Both ECE and McGaugeys spindles are 2.5 inch drop, not 2. Bell Tech makes a 3 inch drop spindle now too.
I do not agree with 67 fleet on the rear. Anyone can sell you a 6 inch rear spring, and there is no need to notch the frame for a 6 inch rear drop. Here's my 6 inch rear ECE drop. Notice how much room is between the frame and axle. You can put your fist between the axle and frame. I hauled a fully dressed 454 big block and a turbo 400 trans in the bed and it still didn't bottom out. That's better than 700 pounds of load. No bumps or rubbing.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
