Old 08-13-2005, 11:05 AM   #1
mvpco
Accel Distributor HEI info needed
Hi All!
I am putting an Accel HEI Distributor in my 72 Chevy C10 350 Auto, is there an adapter harness that goes between old hookups and new connector on HEI Distributor, and what is the part#
Thanks!
Jeff Smith
Pensacola, FL
850-475-5030
mvpco@yahoo.com
mvpco is offline   Reply With Quote
Old 08-13-2005, 12:34 PM   #2
pjmoreland
pjmoreland's Avatar
You aren't going to want to use the old ignition wire because the voltage will be too low (the wire has high resistance). You're going to want to run a 10 gauge wire from the "Ignition Unfused" terminal on your fuse panel straight to the HEI. The yellow wire that comes from the starter motor no longer needs to be connected anywhere.
pjmoreland is online now   Reply With Quote
Old 08-13-2005, 01:17 PM   #3
barn9
Half a bubble off!
barn9's Avatar
What pj said.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 08-13-2005, 04:02 PM   #4
mvpco
Hei
THANKS !!!!!!!!
Jeff
