Old 08-15-2005, 08:24 AM   #1
Jesse72
Jesse72's Avatar
4x4 4spd to th350 crossmember help
I have a question some of you guys probially have an answer to. I had a 4spd and 205. I just bought a 350 and 203 set up when i bolt them in the holes dont line up for the adaptor or the transfer case do i have to get a new crossmember or can i drill mine for the new holes and mover the transfercase mount back? Are the cross memebers from 4spd to auto differend if so does anyone have one?
Thanks any info will help
Jesse
72 4x4 Sold
59 GMC air ride ls swap
Jesse72 is offline   Reply With Quote
Old 08-15-2005, 08:38 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I think your going to have to wing it since the 350/203 combo was not offered in pre-73 vehicles. Do you have access to the cross member that was used with the 350/203 combo? Also, if memory serves me correct the 465/205 and 350/205 crossmembers available in pre-73 trucks are differnet also.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-15-2005, 10:56 AM   #3
Jesse72
Jesse72's Avatar
Thanks, no i dont have access to the old crossmember. But the adaptor lines up to my cross memeber i will just have to drill it, and the transfer case mount looks like it can be moved and it will work fine and then i have to get the drive shafts modded.
Jesse
72 4x4 Sold
Old 08-17-2005, 07:08 AM   #4
gator2511
gator2511's Avatar
Thats what I had to do when I went from a TH350 to a TH400.
gator2511 is offline   Reply With Quote
