Old 08-16-2005, 06:03 PM   #1
jamal
jamal's Avatar
steering play
I have a 98 z71 with 35x14.50x16.5 swamper radials and a 9" lift(6 suspension 3 body) and I have bad play in my steering. Any idea what I could do to fix this?
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 08-16-2005, 08:24 PM   #2
jamal
jamal's Avatar
ok found out it is in my steering box. What years will interchange and what is the cheapest way to fix it? I just built the motor so money is a little tight
Old 08-16-2005, 08:32 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
How was the idler arm? it should mount to the frame opposite the pitman arm. I've read they could go "bad" develope slop.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-16-2005, 08:40 PM   #4
jamal
jamal's Avatar
I had my wife turn both ways until she started feeling pressure and the steering arm never moved so I am sure that is bad, may find more things wrong as well, but starting from the top.
Old 08-16-2005, 08:48 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
How about the rag joint? Might just need a new steering shaft, one w/ u-joints.
Old 08-16-2005, 08:52 PM   #6
jamal
jamal's Avatar
just replaced it and was hoping it would fix it, but it didn't
Old 08-17-2005, 04:45 AM   #7
Mudder
Mudder's Avatar
I run 35's and I found that too much air will make em be all over the place. I run about 20-25 lbs in my Swampers.
Mudder is offline   Reply With Quote
