Old 08-18-2005, 10:19 PM   #1
redgoatroper
caddy to chevy 4 wheel drive
What are my options for putting a caddy motor in a chevy 4x4?
Can the tail shaft be taken out of the caddy and be replaced with
a turbo 350 one? Any help would help. Or someone once said something
about a tranny out of a diesel pickup would work? Thanks for any help.
redgoatroper is offline   Reply With Quote
Old 08-20-2005, 06:11 PM   #2
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
i've done it, you gotta get a pontiac / buick/ olds t350 (shortshaft) and put your 4x4 trans guts in it so the shaft length will be correct, you wont be using the tailshaft portion of the housing good luck
Superron21 is offline   Reply With Quote
Old 08-20-2005, 08:08 PM   #3
Americanrider
V-6 bells to Caddy motor
I have heard from one person that the Bellhouse from a older Buick V-6 oddfires [225 & 231 CID] will bolt right up to a Caddy motor. They used those engines in 67-72 Jeeps, after 72 Buick bought the rights back for the motors and started putting them in their cars due to the performance and pending gas shortages of the 70's. In mid 77 the switched to an even-fire motor and they where weaker.
Oddfires can be found in mid 70's Chevy Vegas and Buick Skyhawks (Vega copy car) As well as some of the smaller 2 & 4 door Buick Specials. I'm only repeating what I have heard, maybe some other member can comfirm or deny this.
Americanrider is offline   Reply With Quote
Old 08-27-2005, 10:48 PM   #4
safensnd
I have used caddy engines for years in my boats and recently put one in a 2 wheel drive 85 short bed, but with caddy tranny......the people to contact about your problem is Flashcraft aka cad company 505-823-9340 ask for chris.....also try cad500parts.com
safensnd is offline   Reply With Quote
Old 08-28-2005, 08:25 PM   #5
hilljob26
hilljob26's Avatar
talk to cadiac,he is a huge caddy motor fan,he should be able to help
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-28-2005, 09:35 PM   #6
FUNMUDDER
FUNMUDDER's Avatar
Personal Message Longhorn Man. He swapped in a cadillac in his 1 ton longhorn. Did a good job, too.
FUNMUDDER is offline   Reply With Quote
Old 09-13-2005, 08:14 PM   #7
stan79chevy
stan79chevy's Avatar
cadillac engines have the same pattern a BOP right?
then something like this should work. http://cgi.ebay.com/ebaymotors/ADAPT...QQcmdZViewItem
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
