Old 08-21-2005, 10:37 PM   #1
brandonh
brandonh's Avatar
73-87 front end
im going to run 73-87 chevy front spindles on my 69 chevy do i have to change the upper and lower control arms to do this or will the 69's work?
Brandon
67 chevy CST
68 chevy stepside US ARMY truck
69 chevy longbed green and white Custom10
05 Honda Rancher AT with 26 inch ITP 589's
2008 Chevy crewcab vortec max 4X4 pickup
1969 Chevrolet layin frame Project Fools Gold
http://67-72chevytrucks.com/vboard/s...d.php?t=257593
brandonh is offline   Reply With Quote
Old 08-21-2005, 10:55 PM   #2
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
no you don't just the ball joints and outer tie rod ends with adapters to mount to the 69 inner tie rod ends or better yet go to the yard and get the entire steering linkage from a 71-87
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 08-22-2005, 03:04 AM   #3
aquik72gmc350
You can use 73-87 Suspension items on 67-72 Trucks but you must do as following:
Must use:
Upper and Lower Control Arms 73-87
Shafts must use from 73-87
Spindles from 73-87
Ball joints must match Spindles
Must use outter tie rod from 73-87
Must use inner tie rod from 67-72
I'm in the process of Building a different front end for my 72 GMC C-1500. I'm using the above items on a 73-87 crossmember with all new Moog parts, 3'' lift Springs from FabTech, all new Disc brake items, and braided brake lines. I have part #'s from the items I'm using if you want them.
aquik72gmc350 is offline   Reply With Quote
Old 08-22-2005, 10:27 AM   #4
69 longhorn
No, you dont need to swap the a arms. if you use the balljoints & all steering linkage from the later truck, it all fits. you may find that you need to grind the steering stops when using the 67-70 lower a arms ,with the 73 up spindles tho. I used 71-72 lower arms ,with '75 spindles & didnt have any problems . best of luck.... L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 08-22-2005, 11:47 AM   #5
aquik72gmc350
My bad!
Old 08-22-2005, 12:54 PM   #6
raggedjim
raggedjim's Avatar
I could be wrong but I believe you will need new flexible brakeline hoses...
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 08-22-2005, 11:20 PM   #7
69 longhorn
Yes, the brake hoses do need to be replaced! I used all the pcs from a '75 c-10(lines , hoses,calipers,master,prop valve,wheel cyls ect) . For a manual disc setup,she stops good crazyL
