Old 08-21-2005, 03:45 PM   #1
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
Torque converter/flexplate?? help
yesterday i got the t/c put into the tranny i know i got the notches lined up and all cause it went the whole ways in and the fins on it almost rub the tranny. when i bolted tranny back to motor there is a gap big enough to fit my finger through btween t/c and flex plate. now qwestion is. can i just pull t/c out a lil till it hits flex plate or have i screwed sumthing up. really dont wanna bust sumthing in the t/c when i go to drive it casue parts store will only take it back if i havnt put tranny fluid to it. im confused wit this please help
87' Silverado 4x4
"Young, Dumb And Full Of Cum"
TireSmoke420 is offline   Reply With Quote
Old 08-21-2005, 04:27 PM   #2
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
The space you are referring to is normal. Just slide the t/c to the flex plate and bolt her down.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 08-21-2005, 04:49 PM   #3
TireSmoke420
ok thnks just wanted to make sure i wasnt going to slide it out and bolt it down. then start driveing and bust sumthing. dont know much about trannies but i can sure make a truck look good. lol
87' Silverado 4x4
Old 08-21-2005, 10:00 PM   #4
rage'nrat638
rage'nrat638's Avatar
what he said......use the correct bolts.......your set.....
rage'nrat638 is offline   Reply With Quote
Old 08-21-2005, 10:26 PM   #5
70 net440
Junior Member
70 net440's Avatar
Depending how big your fingers are you may have too much clearance. You can shim up the gap with washers, but you should use a caliper to make sure they are flat and the same thickness. If the clearance is less than 1/4" you should be fine.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 08-21-2005, 11:45 PM   #6
krue
Designated A-hole!
krue's Avatar
Sounds normal to me. Bolt it up good and tight.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-25-2005, 01:04 AM   #7
TireSmoke420
got everything put back together today. runs and goes awesome
87' Silverado 4x4
