08-25-2005, 10:47 PM | #1 |
heater hose question
Does it make any difference where the hoses go from intake/water pump to heater core?? Thanks
70 C/10 LWB 69 Cougar 68 Mustang 68 GMC 4X4 SWB |
08-25-2005, 10:55 PM | #2 |
its all about the +6 inches
not really. Hot water in....cool water out.
08-25-2005, 11:08 PM | #3 | |
08-27-2005, 10:51 PM | #4 |
"Ochre Ogre"
Huh? There is a right way to do them. 5/8" hose from the intake manifold to the bottom of the heater core. 3/4" hose from the top fitting to either the radiator or the water pump depending on what you have.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
08-28-2005, 07:36 AM | #5 |
1997 GMC Sierra Ext 1965 Mustang |
08-28-2005, 08:45 AM | #6 |
I know its a dumb question....But the reason I asked was, I hooked everything up as follows:
Top core 3/4 to the intake....Bottom 5/8 to the nipple on the water pump. I did it thinking that was the way it went. I started looking at pictures on here and see they are the way you describe. I'll have to go buy more 3/4 heater hose to change it. Thanks!
70 C/10 LWB 69 Cougar 68 Mustang 68 GMC 4X4 SWB Last edited by Fatback; 08-28-2005 at 08:48 AM. |
08-28-2005, 11:32 AM | #7 | |
08-28-2005, 05:23 PM | #8 |
Hey Fastback,
To be correct it needs to be the way da-burb posted. While it will work hooked up backwards, its not the way GM intended it to be setup. The hotest water in the engine goes out the 5/8 hose on the intake and goes into the lower nipple on the heater core also 5/8. Cooler water returns from the top 3/4 inch nipple to either the radiator or waterpump which will also be 3/4. When dealing with hyrdaulics or any kind of fluid pressure system, the return line will always be the larger line. Thats why one nipple is 5/8 and the other is 3/4, they didn't accidently do that! Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
08-28-2005, 08:18 PM | #9 |
will it hurt it if it is backwards,is there something that can happen,or will the heater just not be as hot,just curious
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
08-28-2005, 10:44 PM | #10 |
not as hot? Nothing you'll ever be able to feel...no damage either.
08-28-2005, 11:12 PM | #11 |
It's correct now. Thanks for the info!!
