Old 08-26-2005, 10:46 AM   #1
72MARIO
72MARIO's Avatar
1988-1998 bench install.
I installed my 98 bench back in mid july. Now that I have got around 3000 miles on the truck I find that the seat might need to be tilted back. This may sound kinda dumb but there is no thigh support I bolted it flat to the floor. Anyone else out there mount theres that way ? How does it feel to you ? I am thinking of pie cutting the brackets so that it tilts back more. I couls put a spacer under the front but the seat sits hight enough as it is.
Later,
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-26-2005, 02:58 PM   #2
Deuce
Deuce's Avatar
I'm about to do the same seat, just had to take it apart and paint the steel mounting brackets. I'll let you know how I make out.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 08-26-2005, 05:57 PM   #3
neonlarry
neonlarry's Avatar
I have a 92 bench and I found mine just the opposite I had to shim the rear with a couple of nylon furniture wedges with a hole drilled for the bolt and put them between the bracket and the floor. Raises the rear up about 3/16-1/4".
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
