Old 08-26-2005, 12:35 PM   #26
farside847
farside847's Avatar
Is there any truth to the rumor that leaving your tailgate down increases MPG?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 08-26-2005, 12:36 PM   #27
86swb
Born a Chevy Man
86swb's Avatar
Originally Posted by 8bolt
Gas up here in Canada is near 5 bucks a gallon I hope this will make your truck seam a little easyer on gas.
$5.00 a gallon? Do you guys up there make twice the money we make in the states?
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 08-26-2005, 12:38 PM   #28
86swb
Born a Chevy Man
86swb's Avatar
Yes, it does help. Cuts down on the drag. Anyway, that is what I have always been told.
Old 08-26-2005, 01:02 PM   #29
Scooter67
Skinny tires have less rolling resistance than wide ones. If they're tall enough, they can look pretty good on a truck too.
Scooter67 is offline   Reply With Quote
Old 08-26-2005, 01:31 PM   #30
Jim_PA
Also, keep the tire pressures higher, but don't go over the max listed on the tire.
It might ride a little rougher, but helps with rolling resistance as well.
Jim_PA is offline   Reply With Quote
Old 08-26-2005, 03:13 PM   #31
HeavyD
HeavyD's Avatar
No, we don't make more $$ and get taxed to death. Everyone I know just sucks it up and swears at the pump as they fill up.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-26-2005, 03:19 PM   #32
86swb
Born a Chevy Man
86swb's Avatar
So on a 20 Gal tank, to fill up it cost you $100.00? That is not good. Are there a lot of scooters there? Wow. I should not laugh, it could be that high here in the states soon.
Old 08-26-2005, 03:52 PM   #33
Ozark Tim
Ozark Tim's Avatar
So you have heard plenty of good ideas about how to strech the miles out of each gallon of fuel you burn, and here is one more idea. Sounds like you were into power before and have a camshaft that is suited for that purpose. Have you ever worked with advancing or retarding your cam timing? I have, and you can change the timing to accomodate where the engine makes more or less horsepower by doing so. Of course there are limitations to how much you can change but 3 degrees of advance might work wonders for you, and you can buy the cam gear and a kit of press in bushings with different degree changes. You can even drill and press into your existing cam gear if you like. Off the motor of course. If you were to change your gearing overall in the rear differential, or the final drive ratio, i.e. ( overdrive ) and make some camshaft changes to put the power where you want it to serve you best you should see some improvments.That also goes for changing the advance curve on the distributor. Most people do not have a way to measure this, but if you know someone with a machine to test it you can give that Chevy something that all small blocks love, lots of advance timing. It also effects the mileage if manipulated correctly. By the way my bone stock original 71 Custom-10 with 350 V8, turbo 350 auto, and 3:07 differential gets from 13.5 to 15 mpg. That is with the original quadrajet and 92k miles.
Good luck,
OT
Ozark Tim is offline   Reply With Quote
Old 08-26-2005, 04:54 PM   #34
72str8flush
72str8flush's Avatar
I believe it works but have always heard that your bed sides might weaken and get out of line. Both made sense, so I left mine up. Saving a lil in gas didn't seem to justify having bowed in bed sides.
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over.
_______________________
2006 VW GTI
72str8flush is offline   Reply With Quote
Old 08-26-2005, 06:34 PM   #35
see ten
WTB this ad
see ten's Avatar
Originally Posted by Jim_PA
Agreed, but if you care that much about a thumbs up, suck it up and pay the extra gas money.
Not only am I burning less gas, I took a truck that wouldn't turn over the tires at a standstill and made it have the "one wheel appeal" all the way up to 3rd gear. Not to mention with the cost of fuel these mods will pay for themselves over time. Yeah it still sucks at the pump, and the wife and I have agreed our next vehicle to come in the yard has to get no less than 20mpg. The thumbs up are just a little perk of driving an old truck.
see ten is offline   Reply With Quote
Old 08-26-2005, 07:30 PM   #36
Martin64
Martin64's Avatar
Here's my answer to high gas prices. It gets pretty good mileage and looks cool doing it..... I leave the truck parked as much as possible.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 08-26-2005, 07:51 PM   #37
86swb
Born a Chevy Man
86swb's Avatar
A lot more people might start buying those now. Heck, it is a good excuse to get one if you always wanted one. Just tell the little woman how it will pay for itself in no time.
Old 08-26-2005, 09:57 PM   #38
see ten
WTB this ad
see ten's Avatar
Originally Posted by wlarue72
see ten
I really like your set up with the electric fan, but flex a lite web site does not recommend for the main cooling source on a 4 core radiator. What do you think about this. I have a big block with air and a 4 core.
David
I wonder why they don't recommend it for a 4 core. Try and call a Tech and see what the reason is. They did suggest using this fan on my K10 and I liked it so much I used the same setup on the C10.
Old 08-27-2005, 01:20 PM   #39
SERE
"AIRBORNE"
SERE's Avatar
Clutch fan
I run a 454 with a stock fan. Would a clutch fan work to increase the MPG?
69 GMC 2500 4X4 long stepside 454 BB
SERE is offline   Reply With Quote
Old 08-27-2005, 03:52 PM   #40
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Yep. Don't know how much though.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 08-27-2005, 04:36 PM   #41
SERE
"AIRBORNE"
SERE's Avatar
cool
Thats good. I will try to let you guy's know how much the clutch fan helps. I just bought one I am putting it on this weekend.
Later
Old 08-27-2005, 05:55 PM   #42
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Gas is $2.75 here in oregon cost me about $55 to fill up my blazer and it last's me longer than the $85 to fill up my expedition so if a truck is gonna leave my yard its gonna be the turd.......Btw way if you bought one of these trucks for milage you bought the wrong truck.......
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-27-2005, 09:15 PM   #43
wlarue72
see ten, thanks for the response. I will call them. Looks to me that it should be no problem and will surely help on the gas mileage.
72 Cheyenne Super 402 daily driver. A lifetime project!
wlarue72 is offline   Reply With Quote
Old 08-27-2005, 09:49 PM   #44
71-longbed
Its Magically Delicious
71-longbed's Avatar
Couldn't of said it better .... i'd take my 71 over a new "plastic truck" with a huge monthly payment any D&$m day
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-28-2005, 08:11 PM   #45
Boog
laying low
Boog's Avatar
Ah leave the tailgate up and put on a bed cover. They're cool and should get better results.
My 69 will be a gas hog for sure with a t350 and 4.11 gear but it won't be driven that much and I have a 3.08 to swap out later.
I looked online for that #295 flexalite fan kit and didn't find it. Found other numbers close to it though. Not bad pricing.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-28-2005, 10:39 PM   #46
see ten
WTB this ad
see ten's Avatar
Try this link.
http://www.flex-a-lite.com/auto/html...-electric.html
Old 08-29-2005, 07:53 PM   #47
Boog
laying low
Boog's Avatar
Yeah, that works. Looks like it has plenty of cfm. Clean installation.
Boog
primer is finer
Old 08-30-2005, 08:16 AM   #48
mrein3
mrein3's Avatar
Before you all run out and buy a donor cycle er I mean a motor cycle, please don't if you have a family. I hate seeing a young, now single mom try to raise a family with the bread earner in the family splattered on a guard rail.
I know a doctor who does call them donor cycles. Usually they are crashed by 20-something males full of healthy organs. And they usually come in with just a head injury so just about everything is usable.
Besides I understand donor cycles only get 30-40 miles per gallon. You can do that in a Cavilier or an Escort.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-30-2005, 11:12 AM   #49
farside847
farside847's Avatar
My old Honda ascott got 60mpg. All the good 'ol days.
They say there are two kinds of riders out there, those that have gone down, and those that will. I have survived two crashes. I was hit once, and the second one there was an accident right in front of me. I skidded to a halt, lost my ballance and fell over - so I guess it doesnt really count sinse I didnt really hit anything...
Old 08-30-2005, 02:04 PM   #50
HeavyD
HeavyD's Avatar
I agree cycles are dangerous no matter who is at fault. My brother lost half his foot years ago aftewr being clipped by a car full of drunks. Would have had his melon splattered all over the place too if it wasn't for the helmet. Wear those things!
