Old 08-29-2005, 01:26 AM   #1
kbeefy
kbeefy's Avatar
4 wheel disc conversion question (M/C)
Okay, so I've got this 70 'burban k20 and the brakes were crap. For several different reasons I wound up putting later model axles under it (D44 and 14bFF) along with a rear disc brake conversion. So now, I have basically mid seventies k20 front brake calipers all around, but still have the stock master cylinder (it's power brakes, btw). They work pretty well, but the pedal is pretty soft and I can push it all the way to the floor. I'm guessing that this little master cylinder isn't pushing enough fluid to work the calipers really well, but it is working fairly evenly, due to the front and rear portions of the master cylinder being about equal.
So, after that enthralling introduction, my questionis this: Does anyone know of a master cylinder I can install that has a larger bore to handle the disc brakes (higher flow, more pressure etc) and is equal front to rear (not like one w/ front disc - rear drum)?
Thanks in advance for any advice!
70 k20 'burban (latest aqusition)
91 k1500 xcab lb
99 f350 (sold)
83 cj7 (huge and for sale)
82 rx7 (auto-x project)
74 VW superbettle
04 summit 800 151 & 05 renegade 600
guns, flying, camping, biking, 4-byin, bbq's and beer!
kbeefy is offline   Reply With Quote
Old 08-29-2005, 02:52 AM   #2
Mudder
Mudder's Avatar
I have nearly the same set up as you. I am running a 67 drum/drum master. When I first did the brakes it was a good firm petal. I have changed to an Auto Zone master and they are soft like you said yours were. I think mine need the fluid removed and replaced with new and a good bleeding. LMC does have a M/C for disk set ups now I see.
Mudder is offline   Reply With Quote
Old 08-29-2005, 09:50 AM   #3
FormerMember
Actually you need to swap out the proportioning valve.
the drum rear valve has a check valve in it that keeps the hydraulic fluid from coming back when you let off the brakes. That keeps the shoes in place so the next time you stop, the shoes don't have to travel out to meet the drum.
In a disk application, you want the fluid to travel as the caliper floats back and forth. You also need the bleed the heck out of the system. Most people put the caliper in the worst possible location for bleeding the brakes. I suggest bleeding the caliper off the rotor, so the air flows out the bleeder valve instead of sitting in the "top" of the caliper.
the GM part number for the disk/disk proportioning valve is # 1257225 P30-60 truck that was a one ton ether lunch or utility truck and had 4 wheel disk brakes.
Can also buy them from inline tube or on Ebay.
FormerMember is offline   Reply With Quote
Old 08-29-2005, 11:15 AM   #4
nu2-72
The 76 Corvette master cylinder is set up for 4 wheel disc, has a dual setup with different sized reservoirs and has a larger bore size for more fluid flow. Check into one of those. You will need the diferent size flow to match the prop valve.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 08-29-2005, 11:34 AM   #5
kbeefy
kbeefy's Avatar
thanks for the good info everyone, I'll check into the prop valve and a vette M/C
91 k1500 xcab lb
99 f350 (sold)
74 VW superbettle
Old 08-29-2005, 11:36 AM   #6
FormerMember
When I looked into the Corvette MC, I couldn't get it to line up with the stock 3/4 ton booster I was using.
Is there a different one?
Old 08-29-2005, 01:21 PM   #7
nu2-72
I do not know of a different one. Several people on here have done this although I cannot remember anyone by name right now. If you are in no hurry, give it some time and people will respond. There is some great info on here. I will do some checking as well. I have all the info at home somewhere.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 08-29-2005, 01:22 PM   #8
nu2-72
Just noticed, kbeefy, you auto-x. We did for a few years with SCCA and the Corvette clubs. Where are you located?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 08-29-2005, 02:39 PM   #9
Mudder
Mudder's Avatar
I have heard too that there is a vette mc that will work but not sure of the year.
Old 08-29-2005, 02:46 PM   #10
FormerMember
I tried a 67, a 74, a 79 and an 85. Couldn't get the right throw on any of them. Even tried to use their boosters and did not want to modify my pedals.
BOY was my parts person pissed!
Old 08-29-2005, 04:59 PM   #11
kbeefy
kbeefy's Avatar
I'm in alaska (anchorage, to be precise). Haven't actually raced anything yet, just had this car and decided to build a racer out of it. Time's been in short supply and progress has been nill for the last year. Theres a pretty cool race held up here in march, I might try to get enough done to be competitive there.
Theres a SCCA chapter and Porsche club up here that do most of the auto-x stuff.
91 k1500 xcab lb
99 f350 (sold)
74 VW superbettle
Old 08-29-2005, 05:38 PM   #12
Musclerodz
Put a hydroboost unit on it off a 3/4 or 1 ton. Should give you brakes galore.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
