Old 08-29-2005, 09:59 PM   #1
brandonh
brandonh's Avatar
need front air bag setup pictures
i need to see how i need to setup my front air bags on my 69 chevy pickup everything is stock a arms and lower control arms. like do i need cups on top and bottom and if i do how do i weld them in or what do i do im new at this plez help
Brandon
67 chevy CST
68 chevy stepside US ARMY truck
69 chevy longbed green and white Custom10
05 Honda Rancher AT with 26 inch ITP 589's
2008 Chevy crewcab vortec max 4X4 pickup
1969 Chevrolet layin frame Project Fools Gold
http://67-72chevytrucks.com/vboard/s...d.php?t=257593
brandonh is offline   Reply With Quote
Old 08-29-2005, 10:09 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
You will need plates on top, and cups on bottom. The plates should be bolted in so they can be removed when needed. These pics are from 73-87 trucks but your front suspension should be the same....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-29-2005, 10:30 PM   #3
brandonh
brandonh's Avatar
bags
i was told not to use the plate because you couldnt get the truck down that far with them im zing my from 3 1/4 so i need to be able to lay frame also have 3inch drop spindles .
Brandon
67 chevy CST
Old 08-30-2005, 01:20 AM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can see from the pic's you won't lay the cross member unless you modify it and you may also have to section the cross member as well. there is a disscussion on the forum about the cross member sectioning and I think one about changing the locations of the lower A arms so the are higher up on the member.
Old 08-30-2005, 01:23 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Just incase the frame looks odd its a 58 3100 frame narrowed with a 75 c10 cross member.
Old 08-30-2005, 02:04 AM   #6
1sick7
i have a top plate bolt in too i got 2 1/2dropped control arms and the bags sit in them and 2 1/2 dropped spindles and z'd my frame 2 1/2 and this is the end result
1sick7 is offline   Reply With Quote
Old 08-30-2005, 10:27 AM   #7
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
nice setup 1sick7. You have any more pics of it?
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 08-30-2005, 11:30 PM   #8
bagged_gmc
Shaved
bagged_gmc's Avatar
1sick7, are you the guy with the single huge bag on the rear of your truck with like a spider web of brackets? If so, it looks great!
bagged_gmc is offline   Reply With Quote
Old 08-31-2005, 02:26 PM   #9
1sick7
i had that big bag but change it up abit
Old 08-31-2005, 05:39 PM   #10
MEANGREEN70
MEANGREEN70's Avatar
z'd frame
i dont mean to sound stupid ? but what does z a frame means?
MEANGREEN70 is offline   Reply With Quote
Old 09-03-2005, 12:31 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Z a frame means you cut the frame and move a section up "x" amount of inches. Here are some pice to better explain....
Old 09-03-2005, 12:32 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
2......
Old 09-03-2005, 12:33 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
3......
Old 09-03-2005, 09:39 AM   #14
MEANGREEN70
: n2trux. thanks for the info and the pics, I am working on a 70 chevy, right now the frame hits the floor. I hear alot of people talking about "z " frames and i didnt know what it was, but thanks to you i do now
Old 09-14-2005, 12:02 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Your very welcome. It's an old school trick that was around way before bags, dropped spindles and other modern methods of lowering were an option. It wasn't untill the past few years that it started coming back into play.
Although I would Z a frame before I would "ever" consider a body drop I still have reservations about cutting up a frame. When done correctly it's a viable solution to getting an extra few inches of drop. I'm concerned that some Z'ed frames are mere hack jobs....
Old 09-14-2005, 01:16 AM   #16
bagged74
its just $$$$$
bagged74's Avatar
Originally Posted by brandonh
i was told not to use the plate because you couldnt get the truck down that far with them .
bagged74 is offline   Reply With Quote
Old 09-14-2005, 09:04 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
i was told not to use the plate because you couldnt get the truck down that far with them i.....
How do you mount the bags if you don't use a plate? Do you mean cup? I don't get it?
Old 09-14-2005, 01:26 PM   #18
brandonh
brandonh's Avatar
well i thought i read somewhere one guy put bag cups instead of the big plate that goes on your crossmember but maybe i read it wrong. i guess that is the way to do it, i guess i was wrong
Brandon
67 chevy CST
Old 09-14-2005, 11:31 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
That's cool! I was just trying to figure out how that was possible. I have heard of guys not running the cups on the bottom so it will drop more, but it sounds like a bag blow out waiting to happen.....
Old 09-15-2005, 06:31 PM   #20
bigred66
bigred66's Avatar
i am running cups on top and bottom
Atom (bigRed66)
1966- C10
1995- Wide Body Talon
1987- Dodge Raider (4 sale)
2000- 4-door Nissan Frontier
2003- Ford Focus (wife)
bigred66 is offline   Reply With Quote
Old 09-15-2005, 06:57 PM   #21
brandonh
brandonh's Avatar
bigred66 do you have any pictures and do you have any problems with your bag hitting, also what kinda of cups are u using
Brandon
67 chevy CST
Old 09-16-2005, 09:12 PM   #22
bigred66
bigred66's Avatar
Roll a piece of 1/8" thick metal about 1/2"tall in a circle .. Weld it in your crossmember to locate your bag mount cup. This keeps it from moving around. I lay arms pretty hard and it only gave me an inch or so (you may get away with not using them on top). But that’s just me it would suck to be 1 inch short!!! I was told same as you that I needed to run them on top to lay out. I got my cups from Suicide Doors I believe they were the 98ish Chevy kit. By the way I am running 3 inch drop spindles as well..(ask fastbagged68 if ya need more help he helped me allot gave me awesome instructions)
I had to just to make room for the bag I basically just made the spring hole in the crossember bigger with a torch.
This is the best pic I can fined sorry
Atom (bigRed66)
1966- C10
Old 09-19-2005, 09:13 PM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
I really don't see the advantage unless you plan to do a crossmember drop. With mine set up running cups and plates the arms lay on the ground. I'm not sure how much lower than the ground you need to get????
Old 09-19-2005, 10:08 PM   #24
a squarecan
Not to hate at all, but unless you plan on cutting the outter section of your cross member out running cups on top will not help you at all. This is very popular on mini's such as Sdimes to run bags up top and cut away at the cross member to allow the back to raise up higher. On these trucks I would just plate it though. Jason sells a kit for like $60 and all you have to do is drill some holes and bolt it in. I am getting ready to shorten my bottom cups some, but you really dont need too. But 1/2 inch is a 1/2 inch when you want to lay body.
Keith
a squarecan is offline   Reply With Quote
Old 09-19-2005, 10:35 PM   #25
bigred66
bigred66's Avatar
I agree on the cups. I plan on doing a crossmember drop (some time in the future) I just did it b/c I was told you could not lay out with out them on top. Like I sayed I think you could get away with the plate on top as N2TRUX showed you can. I would go that way if i did it agin. ""But 1/2 inch is a 1/2 inch when you want to lay body"" i like that! thats what i did the cups LOL
Atom (bigRed66)
1966- C10
