Old 08-29-2005, 05:45 PM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Van Tilt column
Hey guys
I am sure some of you have done this a million times and probably heard it asked that many times too. I have a 72 van tilt cruise auto column. I want to put it into my truck. I have heard there is some conversion necessary, then I have heard it is a direct fit. (Personally I think it looks a little long)
If there is already a thread(which i am sure there is) point me in the right direction
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 08-29-2005, 05:56 PM   #2
rays68
here are some links
http://67-72chevytrucks.com/vboard/s....php3?t=133937 http://67-72chevytrucks.com/vboard/s....php3?t=147355
rays68 is offline   Reply With Quote
Old 08-30-2005, 03:29 PM   #3
chevyguy_72
Vintage Evil
Those are very helpful but i still have a problem.
This column doesn't have a neutral saftey switch at all. It doesn't really look like it has a place for one.
Thanks in advance for any info
Current Rides:
Old 08-30-2005, 03:55 PM   #4
uncle
Trans. Switch
If the van still has the transmission, check it for a switch.
uncle is offline   Reply With Quote
Old 08-30-2005, 04:02 PM   #5
chevyguy_72
Vintage Evil
Here is the story:
I bought it off a guy in Colorado about 8 yrs ago. He said it was a 72 truck column. Being all of 17. I didn't really know the difference. The levers looked like the right vintage as well as the column itself(shape, etc...)
It had a camaro steering wheel on it when i pulled off the horn button there was a tag behind it that said 72 chevy van. This was very discouraging. So i let the thing sit because i had no way to contact the guy. anyway i found it in my mom garage a couple of weeks ago(thinking it was long gone) And had read a coulple people on here converting them. So I'm here trying to figure it out. I guess it could be a truck column. All i have to go on is that paper tag that i found when i pulled off the steering wheel.
I will post some pics when i get home tonight. Are there any other tell tails to see which it is?
Current Rides:
Old 08-30-2005, 04:24 PM   #6
neonlarry
neonlarry's Avatar
As for looking long, that probably means it is a van column. On the N\S switch this post shows where the van switch is located and how to modify the position to fit in a truck. The N\S switch can be picked up at most auto parts stores if you don't have one. If you don't have the wiring for one the are a few people on the parts board that should be able to fix you up(teeitup or pickmup come to mind).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-31-2005, 11:07 AM   #7
chevyguy_72
Vintage Evil
Here are the pics of it the 1st and the 4th are the only openings in the column
Current Rides:
Old 08-31-2005, 07:08 PM   #8
chevyguy_72
Vintage Evil
is there a how to on the wiring and also how to take the column apart to check bearings and such?
Current Rides:
Old 08-31-2005, 10:06 PM   #9
neonlarry
neonlarry's Avatar
I haven't seen any how to on wiring(its factory). These threads might help on teardown\assembly:
http://67-72chevytrucks.com/vboard/s....php3?t=105608
http://207.44.196.117/vboard/showthread.php3?t=157328
http://207.44.196.117/vboard/showthread.php3?t=156814
